  • August 02, 2025, 01:10:29 AM
Author Topic: ACHTUNG Spitfire .  (Read 5680 times)
ACHTUNG Spitfire .
« on: February 05, 2017, 05:11:18 AM »
Not a bad read , if a bit long winded . Griffon ( Big Block ) Spitfires .
Flight Anaylisis / Performance , and foibles of the vasrious models , mark by mark . And Seafires .
Other Half seems to be multitudinal pilot accounts / action etc etc .
So for the technically inclined , or those intrested in Aerodynamic Dynamics , engineering , and durability / development ,
Itsa notta too a the bad , eh .
From the Library , of course . A E book comes up on google , if your that way inclined .
Re: ACHTUNG Spitfire .
« Reply #1 on: February 05, 2017, 01:08:32 PM »
I have a WWII copy of the Spitfire Pilot's Manual.  In addition to showing the location of all the cockpit controls, it has a section related to the peculiarities of the Spit.  One advised, in case the landing gear doesn't come down properly, to attain altitude and perform a "Split-S" maneuver.  This is supposed to generate enough "G" force to pull the gear down.
Offline Richard Logston
« Reply #2 on: February 05, 2017, 06:40:48 PM »
Floyd, Did it say to have lot's of altitude before doing a split S? Back when I was learning aerobatics in my single place Starduster I split S out of my first slow roll and lost allot of altitude and pushed close to redline. Richard
Offline Skip Chernoff
« Reply #3 on: February 06, 2017, 05:29:50 PM »
Might be a good time to look at Joe Adamusko's Seafires and Spitfires...enjoy! PhillySkip
Offline Bill Johnson
« Reply #4 on: February 07, 2017, 06:31:12 AM »
Looks like the first one would be Griffon powered by the bulge at the exhausts.
I have a Walter Umland Spitfire kit waiting for my building and flying skills to come up to the task.
Best Regards,
AMA 350715
« Reply #5 on: February 07, 2017, 10:07:15 AM »
When it comes to scale exhaust stacks, this one is about as far from scale as you can get.  These exhaust stacks were salvaged from a smaller model, and are laughingly small!  Fortunately, it doesn't detract from flying.
« Reply #6 on: February 07, 2017, 01:15:11 PM »
It's still a great looking plane, Floyd.
The Spitfire is my favorite plane, by far. I think I have 6 models of it waiting to be built, from CL to 1:72 plastic.
Best Regards,
AMA 350715
« Reply #7 on: February 07, 2017, 02:27:01 PM »
Bill I think Joe's Spitfires and Seafires were built in collaboration with "Windy". One of them is powered by a .90! They fly beautifully!....PhillySkip
« Reply #8 on: February 21, 2017, 09:56:38 PM »
I hear ya, Bill. I've got flying, pladtic, foam , Seafires, Spitefuls, Sea Fangs, Spitfire float planes, so many models of the gorgeous Spitfire.
If I win the lottery my friend in England said he'd restore me his Attacker wing, we'd convert it to boil off reservoir for a Griffin Unlimited racer Spiteful hybrid!
Chris...
« Reply #9 on: February 24, 2017, 06:28:43 PM »
Chris...
Think the " Hawker Spitfire " cooling system might be the trick !
A Mk 18 fuse , teardrop canopy , intermediate size empenagge , and the attacker wings ( Gimme ) would likely be ' the most efficent ' Reno Racer
( as its smaller area would be adquate in turns , as would the ailerons , at those speeds . Build in a bit of washout though . S?P )
one could come up with , which is why I was going to scour Pakistan for some Attacker wings , as there were a few there once .
A Napier Sabre might be a hotter set up though , as late series got 3050 Hp .Thing Above got about 485 with full military equipment ,
« Last Edit: February 24, 2017, 06:45:51 PM by Matt Spencer »
« Reply #10 on: February 24, 2017, 10:45:01 PM »
Boil off is the best, easily lowest drag and with the latest tech well controlled.
Griffons aren't the best race engine but I like them and good for 3200 hp. The contra-props off of the Shackelton have at least proven to be fast in modern terms with proper shaping of the blades.
Smallest stab, man. Low wetted area , adequate vertical area with a Sea Fang vertical and ventral fins.
Griffon Tempest and Tornados are good looking though air cooling is no way to race a liquid cooled engine these days.
Chris...
« Reply #11 on: February 25, 2017, 05:45:20 PM »
Chris...
Hey Chris,
I can't wait to see you in a Spiteful.
« Reply #12 on: February 27, 2017, 10:26:15 PM »
« Reply #13 on: February 27, 2017, 10:33:19 PM »
ETC .
If anyones stuck for a paint scheme ,
  • Gravitywell
« Reply #14 on: February 28, 2017, 11:50:24 AM »
I have the Brodak Spitfire waiting to be built and I live just outside of Edmonton, Alberta.  I have looked at this particular paint scheme for some time now but couldn't figure out the colours....you just solved that for me!  Thanks! H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
