General control line discussion => Open Forum => Topic started by: Bootlegger on March 24, 2009, 06:10:39 AM
Title: AARRGHHHHHHHHHH !!! Damn Paint..!!!!
Post by: Bootlegger on March 24, 2009, 06:10:39 AM
   R%%%%         I had some Viper Red mixed with out the "binder" and put But clear in for binder, then sprayed the red about a week to 10 days ago, this am I wiped the plane down with Martin Senior Cleans eazy and the red smeared on to the white !!!!!!!!!!  How do I get this smear off???  I tried wet sanding with 1000 grit used wet, and the red still shows...!!! R%%%%
Title: Re: AARRGHHHHHHHHHH !!! Damn Paint..!!!!
Post by: Randy Powell on March 24, 2009, 11:13:42 AM
Boot,
That's one of the problems when using primary toners with dope. It tends to destabilize the paint until a clear is shot over the top. sigh... You can wet sand it to an extent, but in the end, you may have to back mask and reshoot the white. Better to use windex or rubbing alcohol.
Post by: Bootlegger on March 25, 2009, 05:24:13 AM
  Randy, I thank you for your answer and help. I'll sure give the advice a try. Thanks again, Gil
