  • July 23, 2025, 09:56:59 PM
Author Topic: AARRGHHHHHHHHHH !!! Damn Paint..!!!!  (Read 992 times)
Offline Bootlegger
« on: March 24, 2009, 06:10:39 AM »
   R%%%%         I had some Viper Red mixed with out the "binder" and put But clear in for binder, then sprayed the red about a week to 10 days ago, this am I wiped the plane down with Martin Senior Cleans eazy and the red smeared on to the white !!!!!!!!!!  How do I get this smear off???  I tried wet sanding with 1000 grit used wet, and the red still shows...!!! R%%%%
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: AARRGHHHHHHHHHH !!! Damn Paint..!!!!
« Reply #1 on: March 24, 2009, 11:13:42 AM »
Boot,
That's one of the problems when using primary toners with dope. It tends to destabilize the paint until a clear is shot over the top. sigh... You can wet sand it to an extent, but in the end, you may have to back mask and reshoot the white. Better to use windex or rubbing alcohol.
Offline Bootlegger
« Reply #2 on: March 25, 2009, 05:24:13 AM »
  Randy, I thank you for your answer and help. I'll sure give the advice a try. Thanks again, Gil
Gil Causey
AMA# 6964
