The fuel weight is only about 10% of the total weight and it's only a little ahead of the CG. On real palnes I've flown the acceptable CG range is something on the order of 15% to 35% of MAC, so a small CG shift is well within limits. Furthermore you have the nose weight for inverted flight and more tail-heaviness for the later more complex stunts, so what littel CG shift there is works for you.
