During eaa, the team that works kid venture flies as many as 800 flights a day and always more than 2k flights for the week. I think this will be the 20th year of doing this, so I think there are some lessons to be learned.
The coro plast planes just work better than anything anyone has tried. Last year ZERO airframes were broken, and there were over 2000 flights per year.
I think the flat airfoil will get flexy, but there are some folded airfoiled ones that will work for larger sized airplanes, but we have great luck with norvel 061's
A wooden or foam airplane just does not have a chance.
I would suggest you grab that political sign and try to make an airplane out of it.
2 years ago when we switched, I did not believe that they would fly well.
They are heavier, but not too much, they can be made to look like an airplane. They do not fly too fast. Heck, in a 4 hrs shift, there might be 200 short flights on a circle, if they were not easy to fly and reliable we could not maintain that kind of pace.
They are not stunters.
Also the conditions are not ideal, there are Bell 47's operating close by and wind rotor downwash, can make conditions chalanging. it also gets windy in ohkosh.
Really, try it you will not be unhappy.
They build fast, fly OK and are unbreakable.
They are cheap to build.
I would not build a balsa or foam airplane to teach kids.
http://www.spadtothebone.com/freeplans.htm http://www.rcuniverse.com/forum/m_10612918/anchors_10613016/mpage_1/key_/anchor/tm.htm#10613016
