  • July 05, 2025, 01:31:47 PM
Author Topic: A repurposed gizmo  (Read 1573 times)
Online Ara Dedekian
  • Ara Dedekian
A repurposed gizmo
« on: December 25, 2020, 02:39:56 PM »
      I needed a dust collector system, without parting with any $$$, for sanding cyano or resin applied to balsa. The vacuum chamber of a vacuum forming unit I have fit the bill but what brought it all home was an ancient Rainbow vacuum cleaner. The Rainbow system uses a pool of water in its base to filter and trap the dust and fumes. (Which begs the question; which came first, a bong or the Rainbow vacuum?) It's also much quieter than a shop vac.
     Sanding the cyano was beginning to affect my eyes and breathing. Using the unit eliminated the effects and wearing a mask made it even better. The plastic backed sandpaper works great. It easily unclogs and seems to keep cutting longer.
     Ara
« Last Edit: December 27, 2020, 08:05:40 AM by Ara Dedekian »
Offline pmackenzie
  • Pat MacKenzie
Re: A repurposed gizmo
« Reply #1 on: December 25, 2020, 02:51:10 PM »
Is that a Navigator you are building?
MAAC 8177
Online Ara Dedekian
  • Ara Dedekian
« Reply #2 on: December 25, 2020, 04:28:02 PM »
   A Sig/Herr 1/2A Aquastar.
   Ara
Offline 944_Jim
« Reply #3 on: December 26, 2020, 02:53:51 PM »
And for the DIY guy, there is a mix-mash of plumbing, 5 gallon paint pail, and lid makes a decent wet/dry vac into a water-filter too! I've been wondering if the vacuum might be strong enough to capture the vapors for a loss-less system that may be run indoors.
