  • July 14, 2025, 05:34:51 AM
Author Topic: A question about CA  (Read 1214 times)
A question about CA
« on: May 18, 2010, 01:13:36 PM »
Has anyone had any luck using CA to attach a rear view mirror to a windshield?
Epoxy or JB weld maybe?
I got some stuff from autozone and it did not hold. 5 bucks down the drain.
Offline Bill Heher
  • Fix-it
Re: A question about CA
« Reply #1 on: May 18, 2010, 01:20:51 PM »
I believe the secret to getting the mirror mount to stay attached is cleaning / cleaning / cleaning the windshield and the mount surface. Then after you glue it in place, tape it securely and give it a good 12-24 hrs cure.
The auto store stuff worked for me- but I would bet that good quality hobby CA will hold just as good.
Bill Heher
If it's broke Fix-it
Online Robert Zambelli
« Reply #2 on: May 18, 2010, 01:23:04 PM »
The CA sold by the auto stores is different. It is much more resistant to UV.
« Reply #3 on: May 18, 2010, 01:37:49 PM »
I think it is CA.  If you suspect it of not being good, go to a better class of auto parts store.
99% Isopropyl alcohol, or acetone.  Nothing that has even a hint of grease in it.
My kid had a tantrum in my truck after I glued one of those on; the little puck came off with a chip of glass on it.  Fortunately it glued right back into the hole, and after over a decade the crack hasn't propagated.
« Reply #4 on: May 18, 2010, 01:50:34 PM »
it is NOT CA - it is a UV set glue that using UV light to set.  similar to Loctite 3751 (but then you need a UV light to make it set) that takes about 1 minute.
Offline Phil Coopy
« Reply #5 on: May 18, 2010, 01:51:10 PM »
What Bill said............
Phil
Offline Russ Danneman
« Reply #6 on: May 18, 2010, 01:58:49 PM »
we use the  loc -tite brand with the activator here in the shop.works with no problems.
FLY LOW FLY FAST  RISKY BUSINESS
Offline louie klein
« Reply #7 on: May 18, 2010, 02:08:32 PM »
I even ruffed the spot with some emery and it worked.  H^^ ---LOUIE
