  • July 17, 2025, 11:58:20 PM
Author Topic: ...1/8" sq spruce??  (Read 902 times)
Offline Bootlegger
...1/8" sq spruce??
« on: July 31, 2011, 12:09:09 PM »
  Where can I get some 48" long pieces of 1/8" sq spruce?  Thanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Clancy Arnold
Re: ...1/8" sq spruce??
« Reply #1 on: July 31, 2011, 12:54:47 PM »
Gill
When I need Spruce I go to a local specialty wood supplier and he cuts the sizes I need for me.  I buy the blank and then I pay for the cutting but I get the exact size I need and I pick the blank to be cut up.  This way I select how straight the gain is.
Clancy
Clancy Arnold
U/Tronics Control
Offline david beazley
« Reply #2 on: July 31, 2011, 04:14:17 PM »
Check Aircraft Spruce & Specialty.  I just got some 60" pcs of 3/16.  They can probably hook you up.  When you order wood from their website you can type in special instructions, lengths, widths, etc.
AMA # 2817
Offline Bill Allen
« Reply #3 on: July 31, 2011, 07:56:43 PM »
Gil: Call Tom Morris and if he doesn't have it he can CUT IT!  As with any wood...you need 20 pcs.  buy 50 pcs. so you've got a selection and future inventory. Tom has cut me 48" 1/4" stock and it's beautiful!    Regards/ Bill Allen
Offline Bootlegger
« Reply #4 on: August 01, 2011, 08:54:33 AM »
   Guy's I sure do appreciate all the help/suggestions... y1
Gil Causey
AMA# 6964
