  • June 27, 2025, 07:13:38 PM
Author Topic: Fully restored B-36 on display near Tucson  (Read 1687 times)
Offline Mike Keville
« on: August 01, 2009, 07:09:26 PM »
For those planning to attend next year's VSC (March 16-20), the Pima Air & Space Museum now has the last-manufactured B-36J fully restored and on display among dozens of other historically significant military aircrafts.  A short drive from the VSC site, it's worth a trip.
Offline SteveMoon
    • www.ultrahobbyproducts.com
Re: Fully restored B-36 on display near Tucson
« Reply #1 on: August 01, 2009, 08:01:50 PM »
We've been to Pima several times, and it is definitely worth the trip.
« Reply #2 on: August 01, 2009, 08:36:45 PM »
I will Second that about the Pima Air Museum.  Still can't see it all even with two visits.  DOC Holliday
Online afml
« Reply #3 on: August 01, 2009, 08:37:33 PM »
Wes Eakin
Offline Marvin Denny
« Reply #4 on: August 02, 2009, 11:36:27 AM »
  Very nice pictures.  I do hope that they get all the marking and identification  stuff correct.  It isn't  in the present pictures.
  Still, I would sure like to get out to Pima Museum one more time , if for nothing else, to get a good look at my favorite plane.  This one appears to have been one od the "Operation Featherweight" planes.
  One cannot appreciate the HUGENESS of that bird until you have worked on it for two or three days straight with a minimum of sleep or rest, then when you are finally done, climb up on top of the fuselage through the top cockpit access hatch after  you have finally corrected the problem and accomplished the final run-up check and look back down the backbone.  Got to go put the cowling back on the troublesome engine ---then FINALLY we can go home---  That is when that plane looks a mile long!!!
  Been there done that.
  Bigiron
marvin Denny  AMA  499
