  • July 18, 2025, 03:43:27 PM
Author Topic: A mystery plane  (Read 1083 times)
Offline Ara Dedekian
  • Ara Dedekian
A mystery plane
« on: April 19, 2019, 09:19:38 AM »
        Can anyone identify this plane? It's hanging on the wall of a men's clothing store in Portland Maine. It was built by the owners father in the middle to late 1930's. It's been refurbished by a local modeler for display. The engine looks to be an Ohlson on ignition.
        Ara
Offline Steve Lotz
Re: A mystery plane
« Reply #1 on: April 20, 2019, 02:43:45 AM »
Tethered Trainer?
Offline Gary Dowler
Re: A mystery plane
« Reply #2 on: April 20, 2019, 04:16:04 AM »
Looks to me like it has 3 leadouts.  When was throttle invented?
Gary
Re: A mystery plane
« Reply #3 on: April 20, 2019, 09:39:36 AM »
Ohlsson never had throttles, but did have two speed timers. Some planes back then use a relay to change timing, with a battery in the handle. Others could have used a third line to switch back and forth between the two sets of points in the two speed timer. I think Jim Walker use a relay as shown on the Ohlsson instruction sheet in his Fireballs.
Re: A mystery plane
« Reply #4 on: April 20, 2019, 01:16:32 PM »
Jim Walker's control line patent (I have a copy) shows the O&R spark timer rigged to a 3rd line, and a spring to pull it back to idle.  That sort of works, but the O&R timer, if loosened enough to permit 3rd line operation, tends to get even looser, and even fall off!  I think it would take some re-design of the stock timer to make that work.  I've seen Walker fly a Fireball using that system.  It worked for him.
