Yep, just assemble them and when you charge the pack for the first time, use the slow charge option on your charger, even if it takes 10 to 12 hours. That will even up the cells a bit. Just make sure each cell joint is a good solder joint as well as all other connections so you have no major points of resistance, and you should be fine. It's a good idea to slow charge batteries like these every now and then just for this reason.
