  • July 23, 2025, 04:25:45 PM
Author Topic: A little Info Please  (Read 928 times)
« on: March 14, 2009, 12:41:20 PM »
Can some one check their GB Nobler and tell me what the width of the landing gear is between the axle bends?
Re: A little Info Please
« Reply #1 on: March 16, 2009, 08:36:18 AM »
I am surprised no one has answered this.  The plane you are holding in the little photo is probably just slightly bigger than the GB Nobler.  I would measure and adjust accordingly.  Might start out at say 10 inches.  My thoughts,  DOC Holliday
Offline james dean
  • Rebel with a cause AMA 467575
« Reply #2 on: March 16, 2009, 12:48:23 PM »
Randy,
I'm into Noblers just now and have been for awhile.  Are you needing numbers for fuse gear or wing gear?
James Dean
« Reply #3 on: March 16, 2009, 01:04:48 PM »
Guys,
Thanks for the replies, I found the width, its 8 7/8", that's for the Green Box Nobler.
Doc, I'm not a large man, but I'm bigger then that, The model in my avatar has a 66" span and about 720 squares, considerably bigger then the little 50" Nobler. The track of the gear nearly 19".
« Last Edit: March 16, 2009, 07:25:07 PM by Randy Ryan »
