  • July 17, 2025, 07:39:58 PM
Author Topic: Cowl hold down  (Read 3537 times)
Offline stephen hollier
Cowl hold down
« on: May 18, 2010, 12:34:34 PM »
Can some of you send pics on how you hold down your cowl simple please. I want to do something that hides the fasteners under the cowl. I currently put the fasteners on the outside of the fuse on either side of the plane.
Thanks in advance
Re: Cowl hold down
« Reply #1 on: May 18, 2010, 12:36:50 PM »
On my Nobler I vent the cooling air out of the bottom center of the cowl.  I locate the cowl with plywood tabs on all four corners, and hold it down with a single screw in the center of the cooling outlet.  It's a flat-black screw buried deep inside a flat black vent, so it's hard to see.
Online Paul Taylor
Re: Cowl hold down
« Reply #2 on: May 18, 2010, 12:42:59 PM »
I used a bicycle spoke on my Akrobat. It is very simple and clean. Not my idea.
Online Paul Taylor
Re: Cowl hold down
« Reply #3 on: May 18, 2010, 12:55:15 PM »
I thought I had a picture of it, but I don't may try and post a picture here later tonight. But here is a very simple drawing of what I did.
A bike spoke is mounted behind the engine and the cap of the spoke goes flush with the cowl when you screw it down. Then I put a small screw in the back to hold the back down. You could maybe do a better job then I did but it works and no screws on the side if the plane.
Offline Claudio Chacon
Re: Cowl hold down
« Reply #4 on: May 18, 2010, 12:59:40 PM »
Hi,
This is how I do my cowl hold downs...
Re: Cowl hold down
« Reply #5 on: May 18, 2010, 01:55:17 PM »
two pins in the front and magnets at the rear - will post pics later.  you can not see any fixtures at all - and the magnets hold STRONG
Re: Cowl hold down
« Reply #6 on: May 18, 2010, 03:15:27 PM »
What size magnets?
Offline John Hammonds
Re: Cowl hold down
« Reply #7 on: May 18, 2010, 03:29:35 PM »
Wow Claudio, what a fantastic finish you have on that plane, I like the colour scheme as well (What I can see of it), sort of reminds me of the colours of Kenny Roberts Yamaha GP bike back in the late 70's.
TTFN
John.
BMFA 165249
Re: Cowl hold down
« Reply #8 on: May 18, 2010, 03:41:42 PM »
TTFN
John.
Thanks John.
Here you have the whole story...
http://stunthanger.com/smf/index.php?topic=16395.0
Claudio.
Offline bob branch
Re: Cowl hold down
« Reply #9 on: May 18, 2010, 04:21:17 PM »
Stephen
In the All Amp'd Up Forum I did a T-Rex electric build thread. I use magnets to hold the cowl on. Pics show 4 magnets. The detail of the installation is in the thread... on the first page.
Key to any magnet retention is that the magnets will only provide retention. Lateral positioning must be provided by other means. Tabs on the T-Rex pics .
Joe Ann Fabrics is a good source for inexpensive magnets. More sizes and way less expensive than hobby shops.
Re: Cowl hold down
« Reply #10 on: May 19, 2010, 11:51:50 AM »
You want magnets?  Go to Radio Shack.  They have 'rare earth' magnets.  They are about 3/16" dia and about 1/8" thick.  They hold like crazy.
Re: Cowl hold down
« Reply #11 on: May 19, 2010, 12:09:07 PM »
Mine keys into the nose ring on the front and a couple of screws through the bottom like Claudio's on the back. Works.
Offline Garf
    • Hangar Flying
Re: Cowl hold down
« Reply #12 on: May 19, 2010, 01:31:44 PM »
You want a powerful magnet? Take apart an old computer hard drive. I have one stuck to the side of my tool box that takes both hands to pull off.
Re: Cowl hold down
« Reply #13 on: May 19, 2010, 01:51:07 PM »
But then you'd lose appearance points because of the pry marks around the cowl.
Re: Cowl hold down
« Reply #14 on: May 19, 2010, 04:40:45 PM »
How many remember the old dress snaps they used to show on the plans?  I have never used them but, have a plan or two that does show them. H^^
