  • June 14, 2025, 11:55:06 PM
Author Topic: Modified Fox 35  (Read 973 times)
Offline Rick Bollinger
  • AMA 931589
Modified Fox 35
« on: November 10, 2014, 03:24:03 PM »
Acquired this old Fox 35 stunt and it is highly modified. The P&L look stock but the crank looks like a McCoy of some kind. The head has been milled down to the point that the inside of the head is all but flat. It was completely caked in burnt castor inside and out so it has ran. I cleaned it up and this thing screams. The crank is sloppy and on the stand there is a very fine line between a 4 cycle and a screaming 2. Any one know anything about these mods. I am just curious.
Rick Bollinger
AMA 931589
Offline Garf
    • Hangar Flying
Re: Modified Fox 35
« Reply #1 on: November 10, 2014, 06:44:21 PM »
I got a worn out Fox 35 from Ebay. It was a 1953 model. I reamed the bearing and stuffed a McCoy 35 crank into it. I also had to replace the P&C assy. It runs pretty good.
