  • June 26, 2025, 03:46:08 PM
Author Topic: Canopy flashing  (Read 3037 times)
Offline petermick
Canopy flashing
« on: October 18, 2016, 12:52:41 PM »
Hi All,
This issue has always been a pain in the butt for me.  What is the best/simplest way to remove the excess material from a molded store bought plastic canopy?  I can never get a straight cut using a sissors.
Peter Mick
AMA 9581
  • Gravitywell
Re: Canopy flashing
« Reply #1 on: October 18, 2016, 01:33:24 PM »
You and me both!  I have tried knives, scissors, hot knife, nothing seems to work for me.  I have just started trimming it large, then trimming slowly with a new #11 blade.  That's the only way I seem to get it close.
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Re: Canopy flashing
« Reply #2 on: October 18, 2016, 01:56:58 PM »
I use a template and mark the canopy. then cut it with scissors. I have some curved ones like Ty notes, but I got them for a sewing store.
Re: Canopy flashing
« Reply #3 on: October 18, 2016, 02:22:48 PM »
I have two small curved blade scissors just for that purpose. I think I got them from the local hobby shop, they may have been a Top Flight product long with their panel lines kit.. They are about 5 inches long and work perfect for canopies.  D>K
there is a set of scissors, they are made for cutting Lexan RC car bodies. Tower has them as do most hobbie shops that deal with RC car stuff.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEVT3&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEVT2&P=7
Re: Canopy flashing
« Reply #4 on: October 18, 2016, 02:25:42 PM »
They sale  canopy scissors, first mark the canopy for the cut you want  and then  trim it with canopy scissors
Offline Mike Haverly
Re: Canopy flashing
« Reply #5 on: October 18, 2016, 06:49:50 PM »
Just call me crude but I use my belt sander and get pretty darn close and finish with a Dremel 1/2" drum sander.  It's pretty fast too!  I'm not very good with scissors no matter how small.
Offline David Hoover
Re: Canopy flashing
« Reply #6 on: October 18, 2016, 06:54:49 PM »
Using a belt sander on a canopy, Mike?  Red Green would love it!  I'll have to try that.
Best, Hoovie
Re: Canopy flashing
« Reply #7 on: October 18, 2016, 07:13:25 PM »
Mike uses a lot of duct tape, too!  VD~ Steve
Re: Canopy flashing
« Reply #8 on: October 18, 2016, 08:27:55 PM »
Not duct tape, blue masking tape.  I cover the canopy with tape, mark the rough dimensions with a Sharpie and start whackin' away.  Obviously some discretion is needed.  I can have one trimmed in about five minutes.
Re: Canopy flashing
« Reply #9 on: October 19, 2016, 09:07:28 AM »
Get a rough fit of the canopy to the fuselage mate using whatever combination of tools it takes - sissors, knives, or whatedver.  Then take a sheet of 220 sandpaper draped over the top of the fuselage and start the final fit of the canopy by pressing/sanding the edges of the canopy down over the sandpaper.  Takes a while and might wear out a sheet or two of 220 paper but it works.
Re: Canopy flashing
« Reply #10 on: October 19, 2016, 07:01:30 PM »
 Just cut it close to where you want it and then work it down further with a sanding block and or sandpaper. Be patient, it can take a while, and be careful not to slip and accidentally nick it somewhere with the sandpaper where you don't want to. From there, fit it to the fuse like Keith describes above.
