  • July 18, 2025, 09:22:19 PM
Author Topic: A Bi Slob question  (Read 2408 times)
Offline Bill Hodges
A Bi Slob question
« on: December 13, 2009, 07:32:40 PM »
I am finishing up my new Bi Slob (we won't talk about what happened to the first one).  Like all Slobs, the leadouts come through the strut in an over/under fashion.  The instructions state to put the down leadout on top.  It would seem to make more sense to put the up leadout on top since that matches the handle.
Why put the down leadout on top?  Just curious.
Bill Hodges
Bill Hodges
AMA 12450
Re: A Bi Slob question
« Reply #1 on: December 13, 2009, 08:02:07 PM »
I do not know either Bill. I put my up lead on top on both of the ones I built. Just seems to make more sense to me, but then I may be missing something that the designer knows that I don't.
Offline Roger Vizioli
  • CLiner
« Reply #2 on: December 13, 2009, 08:28:38 PM »
Bill,
Hmmm, I was not sure.
Your question made me go out to the shop to look at my old one.
FYI - up line is on the bottom. Flies okay for me!
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #3 on: December 13, 2009, 09:08:00 PM »
If you roll inward then you'll tend to get up elevator -- unless you're flying inverted.
So put the up lead on top and fly inverted most of the time -- then everything will be fine.
  • CLiner
« Reply #4 on: December 13, 2009, 09:32:56 PM »
Tim,
Good observation! Makes sense to me!  thx!
Hmm, maybe a cross brace on the strut and leadouts at same vertical position might be worth trying? I might config. my old "Slob" to try this, unless someone already has!   ??
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline pmackenzie
  • Pat MacKenzie
« Reply #5 on: December 13, 2009, 10:17:27 PM »
The down line on top might make it less divergent in level flight, but does it really matter ?
A 'slob does not spend much of its time upright and level if you are using it correctly ;D
Pat MacKenzie
(FWIW, my 'slob has the down line on top. I guess i am a follow the instructions kind of guy y1)
MAAC 8177
« Reply #6 on: December 15, 2009, 08:02:08 AM »
My Bi-Slob is built just like the instructions say to build it.  Maybe a little  more engine off set than some use.  Have never had it come in on me even with the violent loops I do.  Even reverse wing over into the breeze.  Last time out I had a brain fade and decked it, taking out the landing gear and ribs on bottom wing.
  • CLiner
« Reply #7 on: December 15, 2009, 07:04:19 PM »
Doc,
you are not the first to do that.
On our scratch builts, we "normally" sheet the bottom of the lower wing out past the gear. dont ask why we now do that! :-)
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Bill Hodges
« Reply #8 on: December 15, 2009, 08:47:40 PM »
Come on, there has got to be someone out there with the definitive answer.
Finished up the new Slob today.  Now it looks like the weather is going to be unflyable for the next few days.
Bill H.
Bill Hodges
AMA 12450
Offline John_Craig
« Reply #9 on: December 16, 2009, 08:21:59 AM »
Where is the CG on the BiSlob?
« Reply #10 on: December 17, 2009, 09:03:27 AM »
You mean we are supposed to check the C-G? LL~ LL~ LL~
Offline Bill Hodges
« Reply #11 on: December 19, 2009, 04:13:21 PM »
I thought checking the CG on a Slob was illegal.
Actually, I would go to the shop and check it but I am out to town right now and will be for a few more days.  Anybody know where the CG should be?
Bill H.
Bill Hodges
AMA 12450
« Reply #12 on: December 19, 2009, 08:32:57 PM »
The plans show just on the back edge of the spar. I think mine balance just a smidgen ahead of that.
Offline Scott B. Riese
  • Just a student of stunt
« Reply #13 on: December 19, 2009, 10:04:00 PM »
The more nose heavy the better the turn.....to a point. My 60 ship likes it!
Scott Riese
Portland, Oregon
AMA 528301
