  • July 23, 2025, 12:50:53 AM
Author Topic: 89000 RPM !!!! Strap this puppy on  (Read 1684 times)
Re: 89000 RPM !!!! Strap this puppy on
« Reply #1 on: January 13, 2012, 07:40:26 PM »
I can't see the decimal point on the tach, but I'm pretty sure it's not 89,000 rpm. In my R/C boat days, a K&B 7.5 inboard would rev >35K and the in-line 4 in the video didn't even sound close to that.
« Reply #2 on: January 13, 2012, 07:53:33 PM »
O
So how bout that engine. Never seen a 4 banger. Think it is a home built?
« Reply #3 on: January 13, 2012, 08:46:47 PM »
O
My guess it he built it up using some factory liners and pistons.
Another thing, at 89K RPM he probably would have have a prop blade stuck through him!
Here's an I-6
Offline Marvin Denny
« Reply #4 on: January 14, 2012, 09:23:36 AM »
  Perhaps it is me, but it looked to me that he had his tach set for four blade prop when he showed the RPM???  That would definitely throw off the reading wouldn't it??
   That sound definitely didn't sound like That high of RPM.
  I Would definitely like to see it in person to believe the 89K+ RPM.
  Bigiron
marvin Denny  AMA  499
Offline Mike Greb
« Reply #5 on: January 14, 2012, 09:30:23 AM »
I would bet that the first 8 is an artifact of how the camera sees the lcd display, not how the naked eye would see it, i would bet it was actually reading 9000 or so.
« Reply #6 on: January 14, 2012, 11:36:52 AM »
yea I was a little sleepy when I posted this and the number really made me sit up.
I have the same tach but it has been so long since I used it I could not tell you much about the display.
Looking at it now, I too think at that speed it would have thrown a blade.
Still cool to see these big engines.
« Last Edit: January 14, 2012, 06:04:00 PM by Paul Taylor »
« Reply #7 on: January 14, 2012, 11:58:04 AM »
Paused it on frame 1:25 and it clearly has 09000  ;)
« Reply #8 on: January 14, 2012, 03:24:40 PM »
Yup, 9k. Multi cylinders sound really "busy", with alternate firing. It could fire one, two, or four cylinders at the same time. Each setup would have a very different sound, and different vibration, torque and horsepower output.  y1  Steve
« Reply #9 on: January 15, 2012, 07:54:24 AM »
Yes, I would agree that the engine is turning about 9M RPM.  I have the same type digital tach and the has two and three blade settings.  For 4 blade setting with a two blade prop, you have to double the reading.  I know from experience that a three blade setting will give fewer rpm readings.
A side note,  if you have eye protection on such as sun glasses you may not see the reading on the tach or even the screen on your digital car radio.   I thought my tach was not working until I took my sunglasses off. H^^
« Reply #10 on: January 15, 2012, 10:50:11 AM »
LL~ LL~ LL~ LL~ Well, Doc; time to think about getting perscription sun glasses....or get some cataract work done. :## ;D LL~ LL~ LL~
