  • July 17, 2025, 10:49:31 AM
Author Topic: 51/60 size profile  (Read 5643 times)
Online James Mills
51/60 size profile
« on: October 19, 2010, 06:17:13 PM »
"51/60 size profile"
           A local flyer has a ST 51 he wants to build a profile around. He is a sport flyer and not interested in competition. I thought of a couple, Tom Farmers profile and profile Buccaneer.
If you take an existing full body design what do you need to change if you make it a profile?
James
AMA 491167
Re: 51/60 size profile
« Reply #1 on: October 19, 2010, 06:19:09 PM »
The fuselage width.
« Reply #2 on: October 19, 2010, 06:20:34 PM »
I believe you should also move the engine centerline down, to keep the same vertical CG.  There's a set of twins in a more-recent-than-a-year Flying Models (40 size); the only change in the profile between them is the engine centerline.
Offline Alan Buck
« Reply #3 on: October 19, 2010, 06:28:24 PM »
buccaneer 746p profile with a st51 is a good chioce stock motor with master/airscrew 12/6 3blade prop
ALAN E BUCK
« Reply #4 on: October 19, 2010, 06:41:45 PM »
Hi James,
Having built a few profiles over the years from plans that were meant to be full fuselage, I don't see a noticeable problem in your "Sport" flier doing the same.  The '57 Nobler was the first one I *converted* (after a crash destroyed the fuselage! LOL!!) and it flew as well as ever.  That was in about 1965.  The "main" problem with profiles, as you know, is not having enough substance, sometimes, to keep away engine vibrations.  That and they are more prone to twisting in the aft end.
Tell him to pick a plane and just make the fuselage a profile!  It has been done many, many times.  And even some WERE competition planes. ;D
The Buccaneer 746 Profile is a good one like Alan said.
Larry Cunningham's Mo' Best is great with the ST G.51.
Big Bear
Online James Mills
« Reply #5 on: October 19, 2010, 10:39:14 PM »
Thanks for the help, I'll pass it on.
James
AMA 491167
« Reply #6 on: October 19, 2010, 11:49:51 PM »
The fuselage width.
  LL~ LL~ LL~ LL~ LL~
 The Sig Fazer makes a good sport plane for something in the size you're looking for. y1
Offline Leester
« Reply #7 on: October 20, 2010, 04:05:33 AM »
The Sig Fazer also has C/L conversion dirrections in the construction booklet.
Leester
ama 830538
Offline Wayne J. Buran
« Reply #8 on: October 20, 2010, 04:46:43 AM »
IMHO one of the best profiles for especially a ST G51 was Dave Trible's Sukhoi. Heartbeat Models,  if you can find one.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Offline Allen Brickhaus
  • ACE
« Reply #9 on: October 20, 2010, 06:35:15 AM »
The Buccaneer 746 Profile has all the work done for you and is available at Flying Models plan service. Call them at 973-383-3355.
Allen Brickhaus
Offline afml
« Reply #10 on: October 20, 2010, 06:59:59 AM »
YEA!  ;D
What Allen said! #^
"Tight Lines!"
Wes
Wes Eakin
Offline Ward Van Duzer
« Reply #11 on: October 20, 2010, 10:05:14 AM »
If you are going to use a kit wing or build from plans of a full fuse airplane be sure to move the bellcrank (inboard or outboard) so that the pushrod comes out along side the profile fuse. Most full fuse pushrods come out dead center on the wing!
W.
Offline Aaron Little
« Reply #12 on: October 20, 2010, 04:33:04 PM »
Noel Drindak made some type of profile some time back that was plenty big and I think it used a SV airfoil so I am sure it flew well.
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #13 on: October 22, 2010, 10:26:09 PM »
I have a ARF Top Flite Tudor with a Fox 50 in it and flies great
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline andrew stokey
« Reply #14 on: October 23, 2010, 08:25:09 AM »
One more addition.  Tom Morris makes a kit of the SV 22 profile that is really nice.  May be more than you are looking for though.  60" span.  But you did say a 60 size.
Enjoy whatever you build.
Andy
« Reply #15 on: October 23, 2010, 08:27:17 AM »
One more thing.  I have two Buccaneer profiles and they fly great with ST .60's
Online James Mills
« Reply #16 on: October 23, 2010, 10:07:11 AM »
Andy
He has a ST .51 he wants to use.  I remember the Bezerker from PAMPA plans by Noel, jsut wasn't sure if it was a bit more than the 51 would handle, although I ran the 51 in my Shark for 8 years or so.
James
AMA 491167
Offline Dalton Hammett
« Reply #17 on: October 23, 2010, 12:11:00 PM »
Hi James
    For 2010 I have been flying a Mike Garmon designed Wedell Williams Racer using an ST .51.   That is a 60" plane with a lot of body but the ST handles it very easily and has a nice slow speed.  It is very capable of the full pattern and has a nice side profile in the air.
Dalton H
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
  • ACE
« Reply #18 on: October 25, 2010, 07:18:46 AM »
The engine on the Buccaneer 746 Profile and the Encore 40 Twins Profile version have had the engine moved to a location so the vertical center of gravity problem has been fixed.  Order the plans to the Encore 40 Twins which includes a full bodied and a profile version of the same airplane.  It also explains what we went through to reset the engine thrust line to get the vertical CG in its proper and respective place.  Both available from Flying Models.
Allen Brickhaus
« Reply #19 on: October 27, 2010, 01:37:20 PM »
Hi James
Dalton H
HI Dalton,
I remember Mike flying the original.  it was a very capable, easy to build (constant chord), sorta scale model.  Mike always designed good flying planes, I sure do miss him!
Mongo
« Reply #20 on: October 27, 2010, 08:15:31 PM »
Besides the Berserker, there's a Profile P-51 in the PAMPA plans list that was designed for the G.51. Hard to beat a P-51...but we have had at least one Brodak P-40 profile ARF with a G.51. The owner/flier is an Expert class flier, and he said he liked the combination. A kit would be a lot more satisfactory than an ARF, of course.  y1 Steve
Offline Balsa Butcher
  • High Desert Flier
« Reply #21 on: October 27, 2010, 10:14:12 PM »
Surprised there has been no mention of Ted's "Imitation". It would be a good choice for an ST-51.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #22 on: October 28, 2010, 01:57:30 PM »
Hi Steve,
I will dig around in the PAMPA plans list, I have missed the P-51 profile plans for the ST G.51..... ???
