  • July 18, 2025, 06:00:00 AM
Author Topic: 40 Size Tsunami?  (Read 902 times)
Offline kevin king
40 Size Tsunami?
« on: August 16, 2020, 05:54:25 PM »
Hi everyone, I am thinking of building another Tsunami, a down sized one to be powered by a Randy Smith ST46. I would like to ask for suggestions on how to go about doing this. I welcome all the info you can throw at me. I tend to put a tremendous amount of work into each model I build and don't want to build in any design flaws or mistakes that will hinder flight performance. I Know there is 40 sized Tsunami plans out there and would appreciate hearing from anyone that has built and flown one or is familiar with the design.      Kevin King.
Offline TDM
Re: 40 Size Tsunami?
« Reply #1 on: August 16, 2020, 06:55:19 PM »
That model is based on the Paternmaster design the same design, that design also inspired the Cardinals and just about all of Windis designs. I would base the 40 size on the Cardinal 40 with modified wingtips and make the fuse scaled to imitate the Tsunami. Do some math to maintain the wing area the same. If you want to adventure a little move the elevator back 3/4-1in back and thin out the wing tip a little 2-3percent less overall thickness compared with the root. Things that will not hurt is geodesic wing construction airfoil on the stab maybe electric conversion a more torsional rigid flaps and elevator.
Offline Dave Royer
« Reply #2 on: August 16, 2020, 07:22:39 PM »
I recently purchased a Tsunami 40 plan from Bob's Your Uncle and that shows engine size as .36 to .51. Might be worth checking out.
« Reply #3 on: August 16, 2020, 11:32:03 PM »
EGAD ;
Im thinkin the Tsunami is Strega dervitive , or V c V . As theyve both goot the ten i9nch thick wing . ( a bit less perhaps , but near .  :()
Whacking a REAL P M 60 down to 57 span , 89% full size .. If , as they say - it is the ideal size for a D S 60 lite , the engines still WIDE & maybe still wants 1/2 Sq Bearers . This is Annoying .
Theres a fred ( some might say THREAD , on the CARDINAL 40  . Ends up being the 92 Cardinal - minus the Center Rib Bays .
Therefore , if you built a ' built up ' cardinal 40 ,, with the ' tsunami ' lumps & bobs , youd be close to what your after , straight of the board .
WHAT ENGINE are you planning for motivation .
https://stunthanger.com/smf/open-forum/windy's-profile-cardinal/msg568125/#msg568125
Id either do the 92 Airfoil trick , or photocopy @ 89% the full size one , if ya gotta tourquey motor .
I figured the PM @ 89% to get a " P M .46 " for the ST 21/46 if built light, or to put the FSR 40 to use , for ' any weather ' use .
Offline jose modesto
« Reply #4 on: August 17, 2020, 02:42:58 PM »
Just watched the video. Amazing model the detailing may be better than the original
I flew with Windy most weekends and this model is first rate. Hope you shared this video with Windy. Amazing
Steve Busso created the plans for the cardinal 51 1992
My recommendation  is to start there
The plans are a work of Art
The wing is not based on the PM 60
Jose modesto
« Last Edit: August 17, 2020, 03:45:38 PM by jose modesto »
Offline Guy B Jr
« Reply #5 on: August 17, 2020, 11:18:10 PM »
The easiest thing would be to obtain a copy of Eliott Scott's "Tsunami 40", designed with Windy. 54" w/s, 36 to 51
You could also use the Cardinal ARF's 54" wing and kit-bash it to make it have the planform of the Tsunami.
Guy Blankinship
Offline kevin king
« Reply #6 on: August 18, 2020, 08:45:33 AM »
Thanks everyone for the replies! ⭐⭐⭐⭐⭐Now I just have to track down some AAA contest balsa.
