What a great discussion!!!
It really adds new meaning to the phrase "Individual results may vary"!!!!!
Bottom line, as always is whatever works, stick with it.
More note of interest. When Windy was evaluating 4S engines, he fitted a Surpass .70 and then later a SAITO .72 to his Tradition. He used Powermaster 10-22 exclusively and each engine had well over 300 flights. Never a problem.
I have some friends in Italy who use 4S engines. One fellow flew his Surpass .70 for four years using 25% castor, ZERO synthetic. It was the first big 4S plane I ever saw and it was amazing.
I do not concur regarding castor inhibiting/preventing blowby - were that true, I would have a lot of scrap metal on hand.
OK, more "fuel" for the fire. A friend flew a semi-scale plane with a SAITO 40A. One day, the engine stopped expensively - you know, that kind of stop where you KNOW something broke and it's not gonna be cheap!
When I disassembled it, I found the inside dry - completely dry as if it had been cleaned with alcohol. Not a sign of oil ANYWHERE. Furthermore, there was not a sign of lube starvation anywhere. Not a scuff on the piston skirt, no galling on the crankpin - NOTHING. The bearings turned smooth-as-silk without a rattle. The cam/tappet interface showed minimal wear.
So, why the abrupt halt? As you may know, the SAITO cam is driven off the crank by a 1:2 spur gear combo. The cam turns on oilite-type bushings. Close examination of the gear showed that a tooth had broken off and wedged between the remaining teeth and the lifter boss, making a small nick in the casting.
That was the only damage. I replaced the cam and lifters as well as the ring and it now runs like new.
Fuel used? As far as I know, straight synthetic, 10% nitro.
Go figure!!
As fa
