  • May 10, 2024, 04:14:22 PM
Author Topic: blank  (Read 644 times)
Online Motorman
blank
« on: January 10, 2018, 08:44:03 AM »
blank
« Last Edit: December 06, 2021, 08:17:45 AM by Motorman »
Offline BillLee
Re: 4-40 Titanium Pushrod Insert
« Reply #1 on: January 10, 2018, 10:26:10 AM »
Some time ago I got the 4-40 Titanium Pushrod Inserts from SHH. I got 2 right hand and 2 left hand. I decided to use both right hand ends and they've been working with no problems. Then I found a way to make the ends from 4-40 bolts using a slightly smaller (.180") carbon rod. Anyway, I have a new build and a piece of the bigger 3/16 rod I can use for the flaps with the 2 left hand rod ends just to use all this stuff laying around. I decide to cut 1/4" off the rod ends because they are way too long and to make a long story short, these things didn't spark out with the cut off wheel or the grinder. From what I can tell dang things are stainless steel.
Did you try and pick them up with a magnet?
Bill Lee
AMA 20018
Offline gene poremba
« Reply #2 on: January 10, 2018, 10:45:46 AM »
 Its possible they are SS. You are correct, Titanium should throw a bright white spark when run against a grinding wheel. Also there should be a weight difference between the SS and the lighter titanium. I buy mine from Central Hobbies and they have been titanium in the past. I have also had SS ones bought elsewhere....Gene
