General control line discussion => Open Forum => Topic started by: Bootlegger on July 26, 2017, 10:31:32 AM
Title: 4-40 Socket head cap screws
Post by: Bootlegger on July 26, 2017, 10:31:32 AM
  Guy's I am looking for some 4-40 x 1 1/2" -- 2 inch allen socket screws that are threaded all the way to the bolt head. I am using them for control horn set up's.
  Any help will be appreciated...
Title: Re: 4-40 Socket head cap screws
Post by: Robert Zambelli on July 26, 2017, 10:52:58 AM
McMaster-Carr
These guys are the best!
  https://www.mcmaster.com/#standard-socket-head-screws/=18o16pp
Post by: Steve Helmick on July 26, 2017, 12:41:46 PM
But McMaster-Carr doesn't have them fully threaded, per Gil's specification. I think the best you can do is "all-thread". Since the stuff from the LHS is made from cheese-whiz, you might search McMaster-Carr for something better, or up-size to 6-32. Alternately, look at Sullivan, DuBro, and Central Hobbies websites.
If you're doing what I think you're doing, watch out for control asymmetry.   H^^ Steve
Post by: Bootlegger on July 26, 2017, 12:58:51 PM
 Thanks Bob and Steve, Steve would you please elaborate on what you are talking about?  Thanks..
Post by: 11290 on July 26, 2017, 01:41:18 PM
The picture of the screws on this site are shown as fully threaded, not sure if they are or not but wouldn't hurt to check.
http://www.homedepot.com/s/%25234-40%2520x%25202%2520in.%2520Internal%2520Hex%2520Socket%2520Cap-Head%2520Cap%2520Screws?NCNI-5
Post by: eric rule on July 26, 2017, 05:30:28 PM
https://www.mutualscrew.com/socket-head-cap-screws-standard-/alloy-steel-fully-thread-socket-head-cap-screws-14630.html
Expensive but what you are looking for.
Eric
Post by: Richard Imhoff on July 26, 2017, 06:59:02 PM
Try https://www.albanycountyfasteners.com/default.asp  all they have is stainless and the prices are great.
Post by: Brett Buck on July 26, 2017, 09:05:05 PM
   I think you will find the screws you want on this page, threaded all the way to the head:
https://www.mcmaster.com/#standard-socket-head-screws/=18o912s
  4-40 socket cap screws, fully threaded, 1/2 long - 100 for $8.47 Item number  91251A110
Post by: John Rist on July 26, 2017, 09:55:14 PM
2" 4-40 fully threades   https://www.mcmaster.com/#standard-socket-head-screws/=18o9pfm
Then go-to 18-8 stainless steel.  Select 4-40.  select 2"
McMaster links always go to the top page and you have to drill down.
Post by: Target on July 26, 2017, 10:33:59 PM
Boot-
I think that Mr H is saying that if you shove a bolt through a control surface, it will likely not be centered above the hinge line, and you will get unequal throws for equal control input.
R,
Chris
Post by: Steve Helmick on July 26, 2017, 11:50:50 PM
Boot-
R,
Chris
That would be correct, Chris. Also, I looked through a bunch of the links posted above, and most showed no full threaded 4-40 x 1.5"  or 2". One did show a 3", but the "units" was "one", and price was pretty rich for one...IIRC, $3.
I gather that Gil doesn't know what "all-thread" or "redi-rod" is. Steel (or other) rod that's fully threaded, from one end to the other. McMaster-Carr probably has it in some decent high strength steel. Any Ace Hardware will have it in larger sizes, but not 4-40.
All the rest of my first post still applies. Sullivan, DuBro, Central Hobbies, etc., in that order. Lots of R/C bods use such stuff for horns. A lot of the CH stuff is Japanese and quite expensive to my view, but you'll see some good (and bad) ideas on all three sites.  H^^ Steve
Post by: Bootlegger on July 27, 2017, 06:54:54 AM
  I have some 4-40 all thread, but thought that it would be too soft, as for symmetry the push rod is threaded also for adjustment.
  Thanks a lot for all the info guy's..
Post by: Target on July 27, 2017, 01:10:06 PM
The pushrod being adjustable has nothing to do with the asymmetry of control throw, it is the non-perpendicular angle from the hinge line to the control attachment point that does it. You'll see when you put it together. The closer perpendicular to the hinge line you can be, the better.
You could angle the bolt forward, but then you would be at a one point of perfection setting, which is what it sounds like you want to avoid.
That is why a nylon hinge has the offset base with the 4 holes in a vertical line. That line is meant to be directly above the hinge line.
You can do a mockup with two pieces of balsa taped together for a hinge, and a dowel representing your 4-40 bolt. Set it back a good distance from the hinge line, then start measuring your throw of your pushrod (shrink tube another separate dowel to the tip of the horn dowel to make a linkage) vs. the up and down throws you get. You will see that there is "differential" in the throws.
We USE differential in RC sailplanes to help combat unwanted adverse yaw, by having the up aileron throw further (typically 2:1 or sometimes more) than the down aileron. We do this by either offsetting the control horn (the oldschool way) or by having the servo arm tilted either towards or away from the linkage (depends on push or pull for up aileron) at neutral....
The closer you can get the 4-40 bolt to that hinge line, the less the effect will be, and in fact if it is very close, you might not really notice it, depending on the angle the pushrod is at from the flap horn and to the elevator horn.
I'm exhausted now from typing!
But, best of luck on your endeavor, and I mean not to dissuade you. Just don't want you to be disappointed or surprised.
V/r,
Chris
Post by: Bootlegger on July 27, 2017, 01:15:28 PM
  Chris, et al thanks for the heads up on this set up, I really do appreciate it.. #^ y1 <=
Post by: Matt Brown on July 27, 2017, 01:29:31 PM
Our local Hobbytown has 12" long 4-40 stainless all thread. I have used it for exactly this purpose. I think it may be a Dubro offering.
Matt
Post by: Bootlegger on July 27, 2017, 03:47:49 PM
  Mr. Zambelli,
   I sent you a P/M...
Post by: Randy Cuberly on July 27, 2017, 05:00:46 PM
This link to McMaster-Carr shows 4-40, 18-8 stainless screws fully threaded in 1 1/2 and 2 "" lengths.  18-8 is plenty strong enough for what you're doing.
https://www.mcmaster.com/#socket-head-cap-screws/=18ook05
As stated above the screw must go through the elevator at the hinge line.  This can be accomplished by building a tab into the elevator that extends into the notched Stab and mount the screw into this tab.  It works I did it a long time ago.  Just make sure the tab material is strong enough to take the control loads.
Post by: Fred Cronenwett on July 27, 2017, 05:45:06 PM
These are two sources that I have used
http://www.microfasteners.com/
https://www.boltdepot.com/
Fred
Post by: Dan McEntee on July 27, 2017, 07:09:59 PM
   The screw doesn't HAVE to be on the hinge line, but the fitting  that the pushrod attaches to should be on the hinge line. DuBro sells a fitting to do just that and uses the same fitting that aileron horns use. It has a large, triangular base plate on both sides of the control surface to spread outthe stresses.
Post by: Robert Zambelli on July 27, 2017, 07:40:15 PM
  Mr. Zambelli,
   I sent you a P/M...
Got it and responded.
Hope the info helps.
Post by: Steve Helmick on July 27, 2017, 07:49:33 PM
"The screw doesn't HAVE to be on the hinge line, but the fitting  that the pushrod attaches to should be on the hinge line. DuBro sells a fitting to do just that and uses the same fitting that aileron horns use. It has a large, triangular base plate on both sides of the control surface to spread outthe stresses.
   Dan McEntee"
Indeed. One idea to strengthen/stiffen the control horn would be to install it and build a "pylon" around it maybe 3/4" tall. Using hard balsa and cellulose glue, it would be easy enough to cut down a bit if needed.
I'll be up front and tell you that I haven't done this sort of elevator horn...when I flew combat, I always used the large Veco flap horns. They made a clean installation, had some adjustability, and spread the load over a fair amount of the stabilator's 3/16" or 1/4" balsa I used. But I'd likely be using the scheme Gil is looking at, if I was going to do combat again (ain't happening!). It would be a help towards get all my models to respond similarly. Seems like a big plus to me. H^^ Steve
Post by: Norm Faith Jr. on July 27, 2017, 09:01:56 PM
https://www.microfasteners.com/ast2468-2-56-4-40-6-32-8-32-socket-head-cap-screws.html
Post by: Bill Mohrbacher on August 01, 2017, 06:50:54 AM
I just bought some 4x40 3 inches long, full length threaded from micro fasteners. 800-892-6917.  Part #SCA0448
I was surprised as shorter lengths were partially threaded.  Call and talk to them, they very nice people to deal with.
