  • June 25, 2025, 06:11:56 PM
Author Topic: La Donna prototype... phase 3 (Flipped over)  (Read 3452 times)
Offline builditright
  • So happy to be alive!
« on: October 29, 2009, 11:24:10 PM »
More on Jack Sheeks La Donna.
The fuselage can be seen in post: "La Donna""
http://stunthanger.com/smf/index.php?topic=14541.0
The top of the wing can be seen in post: "La Donna prototype... phase 2"
http://stunthanger.com/smf/index.php?topic=14621.0
To get on the waiting list or verify that you're on the list
please send an email to: jsladonna@builtrightflyright.com
please include your current contact info, ie: full name, mailing address and phone number.
Okay...  with the custom made controls in, the boom tops and stab taped on the La Donna has now been flipped over so I can secure the pushrod to the bellcrank, install the gear and the reast of the strip ribs.
The controls are custom made for the "La Donna" by Jim @ control line central should be ordered directly from C.L.C. (http://www.clcentral.com)
(* The nylon bellcrank currently shown installed is not a part of the custom controls by CLC, the custom controls will include a phenolic B.C. not nylon)
Thank you and God Bless
Walter
aka/ builditright
Re: La Donna prototype... phase 3 (Flipped over)
« Reply #1 on: October 29, 2009, 11:36:26 PM »
Excellent looking work, Walter (as usual!) and I think it will be a great kit.
Bill <><
« Reply #2 on: October 30, 2009, 04:38:45 PM »
Bill <><
Thanks Bill,
This is only my second I-Beam stunter I have built and it's going together real easy,
so with your I-Beam building skills I know you would love building this one.
Walter
aka/ builditright
« Reply #3 on: October 31, 2009, 05:13:22 AM »
Walter
aka/ builditright
« Reply #4 on: October 31, 2009, 08:17:12 AM »
Seeing the construction as it is progressing causes me to think back to when I built the Sheeks Staggerwing.  One wing with all those ribs isn't too bad, but try two wings.   The build is still looking great.  Did the original have the bellcrank in the outboard boom?  Have fun,  DOC Holliday
« Reply #5 on: October 31, 2009, 11:17:10 AM »
yes it did
Walter
aka/ builditright
« Reply #6 on: October 31, 2009, 12:04:33 PM »
Guess we'll see if the argument about bellcrank placement holds up. Shouldn't make any different, I suppose.
Nice work, Walter.
Offline Leester
« Reply #7 on: October 31, 2009, 05:05:34 PM »
The RSM Crusader has it there also, just gotta make sure you have long lead outs. Really looks good Walter, glad I'm on the list.
Leester
ama 830538
« Reply #8 on: October 31, 2009, 07:48:59 PM »
Walter
aka/ builditright
« Reply #9 on: November 02, 2009, 08:12:49 AM »
Walter
aka/ builditright
« Reply #10 on: November 02, 2009, 12:54:27 PM »
If I could do work like that it would be finished in clear with very little pink trim and graphics.
Offline John Miller
« Reply #11 on: November 02, 2009, 02:31:48 PM »
John, just ask Walter, this kit's fits are very good. It will go together like an erector kit. The cutfiles were set up to use the accuracy of laser cutting, something more and more CAD men are starting to do.
Online Matt Colan
« Reply #12 on: November 02, 2009, 06:32:00 PM »
Boy it's going together fast Walter, and is looking like a very good airplane now!!
« Reply #13 on: November 06, 2009, 08:45:05 PM »
Walter
aka/ builditright
« Reply #14 on: November 07, 2009, 12:11:59 AM »
I think I'll just skip the kit and take that finished one!
Nah! Building it looks like just too much fun. Can't wait!
« Reply #15 on: November 07, 2009, 08:53:58 AM »
I already have a color scheme in mind.  But, as slow as I am it will not be ready for VSC 2010.
Offline Bill Morell
« Reply #16 on: November 14, 2009, 11:30:25 AM »
hmmmm, a mysterious SSW syndrome, missing posts..........
Bill Morell
Vietnam 72-73
Offline Gene O'Keefe
« Reply #17 on: November 14, 2009, 06:45:32 PM »
Beautiful, beautiful workmanship .......but I gotta ask -- why no 1/8" tubing through bellcrank ? - won't leadout cable eventually egg out and wear through bellcrank ? ......or is bellcrank made of super tough material that won't allow cable to wear through ? Sorry to upset apple cart for something I missed or should have known.
   Geno
Gene O'Keefe
AMA 28386
« Reply #18 on: November 15, 2009, 07:53:49 AM »
If that is one of the SIG Mfg bellcranks you will not wear it out.  Even if you take the bare cable and pull it back and forth thru the holes it will take a very long time to cut thru it.  I have one that has been in several planes and shows no sign of wear.  Now look at the motion we put on the bellcrank and tell me how to wear it out.  I have even used the skinny Perfects cranks and no failures.
