General control line discussion => Open Forum => Topic started by: Paul Taylor on October 17, 2021, 12:21:53 PM
Title: 3D Printing ???
Post by: Paul Taylor on October 17, 2021, 12:21:53 PM
I did a search and found a thread of someone printing tanks.
Anyone else print any useful items for CL?
I’m thinking engine offset pads for profiles? Maybe motor mounts for electrics?
Title: Re: 3D Printing ???
Post by: Dave Rigotti on October 17, 2021, 12:27:15 PM
I would think motor offset pads would be too soft and subject to "creep" over time.  Okie Air offers a 3D printed electric motor mount/front end.  With the dozens of styles and sizes of tanks available in metal I'm sure one would be available to fit almost any application with out "scratch" designing one in CAD and then taking hours to print it.......
Post by: Steve Berry on October 17, 2021, 01:02:17 PM
I've been tinkering around with doing line reels, handles, electric motor mounts, and even a complete plane (still in design stage). Lots that can done. My thought is that instead of PLA filament, use ABS filament. Stronger, more heat resistant. A bit harder to print with though since a cleaned heated enclosure with a heated bed is needed to keep it from warping.
Once I get some more stuff sorted, I'm thinking of starting a print-on-demand control line parts business.
Sent from my SM-N986U using Tapatalk
Post by: Mark wood on October 17, 2021, 03:47:51 PM
I am doing a lot of things with my 3D printer. I would not print anything for an IC engine mount from any of the plastics as creep will eventually happen due to pressure and heat. I have bellcranks, Log flap drives, motor mounts for electric (idea plagiarized from Tom Morris and addapted to my models) and I am also contemplating utilization in a model. For high strength I'm using a carbon fiber impregnated nylon which is a bit tricky to work with and doesn't glue well but is super strong and heat resistant.  I have found an ABS variant of this and have hopes for good bonding which will be what is necessary for airplane construction. Think ribs and support parts for bellcranks and such. My printer isn't large enough to do landing gear but they could easily be done using the CF/nylon. Everything I do, I will supply to anyone who requests it.
Post by: Tom McClain on October 17, 2021, 04:52:39 PM
How about RevUp 10x6 EW propellers?
Post by: Paul Taylor on October 17, 2021, 05:53:47 PM
Good stuff Mark. Would you be willing to share STL files?
I’m getting up to speed in a CAD program. I enjoy drawing stuff up almost a much as watching it print. 🤣
Post by: gene poremba on October 18, 2021, 04:55:33 AM
 Paul, PM sent....Gene
Post by: Peter Grabenstein on October 18, 2021, 05:53:14 AM
3D Printing, made/printed in Germany  y1.
https://www.ebay.de/itm/124656583801?hash=item1d061c8479:g:UtIAAOSwOCVgYF3d
rgds
 8) Peter
Post by: Mark wood on October 18, 2021, 07:43:28 AM
There are some people printing propellers. And there are some people printing propellers and having failures. It’s doable but if’n it were me, I wouldn’t. Having said that, one could print a propeller to be turned in to a mold for fiberglass or carbon fiber. I have a couple of those in my doing stuff queue. It’d be a fairly big effort and be easier to just pull a mold off of a Rev Up or other prop.
Post by: dave siegler on October 18, 2021, 07:27:02 PM
I have printed lots of items that I use every day
1) Sullivan starter end caps, now hold a Milwaukee tool battery for cordless use
2) Wheels, motor mounts and bellcranks for indoor control line
3) 1/2 A handles
https://www.thingiverse.com/thing:2877850 (https://www.thingiverse.com/thing:2877850)
4) Assembly aids, jigs and squares
5) Drilling jigs (motor mount jigs
6) 1/2a combat tail boom mounts (very slick)
7) Combat fuel pincher
https://www.thingiverse.com/thing:4577590 (https://www.thingiverse.com/thing:4577590)
things I would like to print:
Profile tank mounts
Metal fuel tank forms (bucks)
Profile wedge tank ( have seen them)
Post by: Paul Taylor on October 18, 2021, 09:29:32 PM
Good Stuff Dave.
Post by: dave siegler on October 20, 2021, 09:05:07 AM
handle, belcrank, wheels and tail boom
