  • July 16, 2025, 10:30:22 PM
Author Topic: blank  (Read 1499 times)
blank
« on: October 02, 2013, 10:28:26 PM »
blank
« Last Edit: September 21, 2021, 06:21:35 PM by Motorman »
Re: Heat gun with Generator
« Reply #1 on: October 02, 2013, 10:45:08 PM »
Hey guys, will this power a monokote heat gun? http://www.harborfreight.com/catalog/product/view/id/9057/category/429/
No, the Top Flite gun is 1000 watts, that generator is 800 watt.
Offline Norm Furutani
« Reply #2 on: October 03, 2013, 12:48:25 AM »
No, but it will power a monokote iron. For dewarping on the field, I use a 400 watt inverter and an iron connected to the car battery. I have a gen, but the iron and inverter is a lot less fuss.
Norm
« Reply #3 on: October 03, 2013, 01:35:12 AM »
After my first few jobs, I quit using the gun. I use the iron without a sock for everything. It takes time and you have to keep shifting to stay in the right light so you can watch the film darken under the heat, but it does a really nice job. It's one of the things I've found I'm really good at. But I only cover ribbed wings and small solid surfaces like the stab. I might find I need the gun if I worked on other things like large solids, I'm not sure.
