  • July 19, 2025, 07:32:13 AM
Author Topic: What is the plane on pg. 22  (Read 1117 times)
Offline GonzoBonzo
  • GonzoBonzo
« on: November 19, 2013, 06:24:17 PM »
...of this months AMA publication Model Aviation?  Some sort of OT stunt.  Nice looking.
TIA
Gonzo
Gonzo
Re: What is the plane on pg. 22
« Reply #1 on: November 19, 2013, 07:08:22 PM »
 I was wondering the same, nice looking design. y1
Offline Allen Brickhaus
  • ACE
« Reply #2 on: November 19, 2013, 07:43:45 PM »
If it is the November issue, it is the Legacy 40, a Brodak kit.
« Reply #3 on: November 19, 2013, 08:06:49 PM »
 Thanks Allen. I was kind of thinking Legacy but I thought the wing looked like it had too much taper. The canopy threw me a little too.
 Hmm, I've got a NIB Legacy .40 short kit, maybe I should get to building it... ;D
Offline GonzoBonzo
  • GonzoBonzo
« Reply #4 on: November 19, 2013, 08:42:54 PM »
Yes Allen, the blue, and white one.  What threw me off was the apparent thin wing,  and sharp leading edge.  I guess pictures can be deceiving.  I should have known better, as I have the kit too, and it is in que to be built shortly.
The plans show more flap than elevator, is this correct?  Or, should I swap the elevator,  with the bellcrank pushrod on the flap linkage which would give it 1 to 1?
Gonzo
Gonzo
  • ACE
« Reply #5 on: November 20, 2013, 05:41:18 AM »
Sharp leading edge is due to builder's choice and the thin wing is a camera perspective.  If you look at the plans, I believe you will find a very modern airfoil.  I am tempted to build one with landing gear in the wing and a piped .40 PA for power.  This is a 565 square inch wing and Jim Aaron had a 575 wing with a PA .65 in it.  I think it would be an excellent PAMPA bird of prey.
Allen
I was wrong on both the areas of the wings and corrected that.  Thanks Steve, old timer's disease is setting in quick.
Allen
« Last Edit: November 21, 2013, 05:39:02 AM by Allen Brickhaus »
Offline GonzoBonzo
  • GonzoBonzo
« Reply #6 on: November 20, 2013, 11:16:54 PM »
Sounds like a winner to me.
Gonzo
