  • June 17, 2025, 06:37:48 AM
Author Topic: Big Batteries  (Read 1481 times)
Big Batteries
« on: March 14, 2025, 05:10:16 PM »
This is in response to a PM from a friend.  I am posting here because you can't attach anything to a PM.  I had a dilemma in finishing my Endgame IV Twin.  With out knowing better I build my electronics around two Spin Pro 33 ESC and a special size 6s 2800 battery pack.  Plane nearly finished I discovered that the Spin Pro would not support a 6s battery.  Make it worse, the 5s TP 2800 fleet was too tall to fit the battery box.  I mentioned this to one of our recent RC crossovers (watch out, these guys learn FAST) and he said he had some 5s 4200's that might fit and he would never use them.  With a little tweaking they fit and here they are.  The pack is 1/4" longer and 1/4" taller than the li-ion 6s pack but smaller than the TP 5s 2800.
In case you are curious, even with the extra weight the plane is still slightly tail heavy.  Why add lead when you can add battery!
Don't know for sure what cells he used but the battery in the PIX powered the Twin Tuesday.
Offline Fred Underwood
Re: Big Batteries
« Reply #1 on: March 14, 2025, 07:05:21 PM »
Nice work, a great way to get more watts than the TP 2800 6s for about the same weight.  Did you make your own?
Fred
Fred
352575
Online Dave Rigotti
Re: Big Batteries
« Reply #2 on: March 14, 2025, 07:20:50 PM »
Because lead is ALOT cheaper than batteries?
Dave Rigotti
AMA 66859
Chesterland, Ohio
Re: Big Batteries
« Reply #3 on: March 14, 2025, 07:26:24 PM »
Fred
We all use Li-ion for the most part and several in our group make them.
Re: Big Batteries
« Reply #4 on: March 14, 2025, 07:27:35 PM »
True dat. y1
