  • July 30, 2025, 09:15:06 PM
Author Topic: 3 blades prop  (Read 322 times)
Offline kevin king
3 blades prop
« on: Yesterday at 12:41:36 PM »
I was balancing a 3 blade prop on my dubro balancer and noticed that one blade was higher than the other 2. In other words the tips of 2 blades would  track in the same spot but the 3rd blade at the tip would track 1/8" further. Anyone have this problem?
Offline Lauri Malila
Re: 3 blades prop
« Reply #1 on: Yesterday at 01:20:09 PM »
It may be just the imperfections in prop hole ends/balancer cones, the Dubro balancer is not very well made.
Check the tracking when bolted to the engine and if it bothers you, sand the bottom of hub to correct. L
Online Howard Rush
Re: 3 blades prop
« Reply #2 on: Yesterday at 05:00:58 PM »
It can make the prop noisy.
Offline Matt Neumann
Re: 3 blades prop
« Reply #3 on: Today at 03:39:13 PM »
Out of curiosity, what prop?
Matt Neumann
