  • July 17, 2025, 05:59:42 PM
Author Topic: 25 sized stunter  (Read 3358 times)
Offline Shorts,David
25 sized stunter
« on: August 12, 2019, 10:36:58 PM »
Hi Gang,
I'm just finishing a Bob Elliot Black Tiger. I've fitted an fp .25 into it and I'm at 1lb 10oz, almost ready to cover. It'll gain a couple more ounces in wheels and spinner and some filler, and then of course whatever my covering weighs. My questions are:
What's a good weight for a .25 stunter to expect it to fly the pattern? Am I going to be woefully heavy and should stuff something bigger in it? It's about 440 sq in. or real close to that.
What's a good prop for a .25 fp? I used 10x4 apc when it was on my barnstormer. Seemed pretty good to me.
I think Brett's Skyray has a .25, and Dennis Nunez has a good flying .25 plane.
David
Online Gary Dowler
Re: 25 sized stunter
« Reply #1 on: August 12, 2019, 10:45:10 PM »
I was flying a Cosmic Wind at 34oz with a 20FP and all the power I needed.  You're likely to come in around 30 when done, and the 25 is a little more powerful than the 20. If anything, you are overpowered. Presently this 20FP is on a CG P-40, at 32oz it also has all the power it needs. Running a 9-4 APC prop, launch at 12,500 (fp's like rpm) and it will fly 6 minutes on less than 2-1/2oz of fuel.
Gary
« Reply #2 on: August 12, 2019, 10:58:23 PM »
Hi Gang,
   26 ounces +say, 6 ounces for finish is 32 ounces, 440 square inches, should be plenty OK with a 25FP. Problem will be keeping it below about 80 mph.
   It's certainly *not* too heavy in terms of wing loading,  and certainly not too heavy for the engine - if anything, its on the small side for a 25FP. This combination should be very potent.
Assuming you are starting with a *completely stock* engine, get someone to make you a venturi about .252" (-.005) and .247" (-.010). Based on very extensive past experience, the stock venturi can be a bit too big for the 25FP, although its great for the 20FP and the 25LA. I would start with an APC 9-4, but if it gets too fast or too rich in flight, go to the .252 venturi. You can try a 10-4 but that will probably require a smaller venturi yet. An ST needle valve is way too much restriction, and you have to damage the case to install it, so don't.
« Last Edit: December 28, 2019, 08:10:00 PM by Brett Buck »
Online Dennis Nunes
« Reply #3 on: August 12, 2019, 11:37:16 PM »
Hi David,
My Circulas 25 started out with stock OS LA25 with the stock muffler. Circulas 25 has a 48” wingspan with an area of 425 sq. in. The current weight is at 37 oz.
I originally used the stock OS muffler along with an aluminum spinner, but this required adding an ounce of tail weight to get the CG in the correct location.
I ended up switching to a very light tongue muffler and a nylon spinner which allowed me to remove the excess tail weight and save about 2 oz. of overall weight. However in changing to the tongue muffler I gained an increase in power of 500 rpm on the engine. In fact I’ve been trying to slow the plane down as it flies too fast. In order to do this I’ve change the venturi to .240” diameter and have been running with an APC 10x3 prop. For windy weather I’ll run the APC 9x4 prop. I’m also running the remote NVA.
Hope to see you and your dad at the Ted Goyet contest.
Dennis
Here is a picture of Circulas 25 before the changes:
« Reply #4 on: August 13, 2019, 10:41:57 PM »
Thanks Gary, Brett, and Dennis, that's exactly what I needed to know for now. Depending on how long it takes to get my front row finish *LOL* I'll try out those suggestions. It does already have an ST needle in it, but if it shows enough promise I'll cross that bridge when needed.
Maybe I'll have it in time for Meet N Meat, but probably who knows.
David
« Reply #5 on: August 14, 2019, 11:30:24 AM »
I wince every time someone says "25 sized" or "40 sized".  25 what?  Your plane would barely go in circles if you used an OS Max 25S, but as Brett says, you'll have to work a bit to tame down the 25FP.
I'm glad that you mentioned the specific engine, and that people were able to give you advise based on that specific engine.  Do what Brett says about the venturi, or use the stock venturi and pile nylon mesh over it (get the foofy stuff that's used for flower arrangements or bridal veils -- it's probably 25 holes/inch or so.  Pantyhose is woven, and stretches weirdly).  If you use a big venturi and you're up to five or six layers of mesh, consider getting a smaller venturi made.
And, like Brett, I ask you to not use an ST needle valve.  They're nice, but the world supply of un-butchered 25FP cases is finite, and gets smaller every time someone drills one out.
Offline Joe Hunt
« Reply #6 on: August 15, 2019, 05:30:17 AM »
what is the proper nva, and where do you get it?
« Reply #7 on: August 15, 2019, 11:04:40 AM »
  The proper needle valve/spraybar came with the engine, unless someone tossed it. There is an Enya replacement of similar dimensions :
https://www.ebay.com/itm/OS-FP-LA-20-46-NEEDLE-VALVE-ASSY-DIRECT-REPLACEMENT-NIP/293139719059?hash=item44407d2393:g:0-8AAOSwJRFcolWt:sc:USPSFirstClass!94086!US!-1
    This was made specifically to fit as a replacement part. I haven't tried it, but it does avoid you having to destroy another OS20/25FP or 25LA crankcase by drilling holes in it to fit an incorrect part.
    The correct venturi size for the correct spraybar assembly is .256"/"6.5mm" for the 20/25FP or the 25LA. This works with the recommended setup.
   Based on painful experience, check the diameter of the holes for the spraybar in your engine. On an undamaged crankcase, the hole in the case to pass the spraybar is 0.1459" in diameter +-.0002". That's difficult to measure without the proper equipment,  but it's 3.705mm, which is about what you will get with a 3.7mm drill, which is probably what they used. As a check, a #26/.147 drill will not go, and a #27/.144 drill will fit pretty easily. This intended to fit the "3.5 mm" spraybar, which measures around 3.506mm, or .1380"+- a few tenths.
     If it has been crankcase has been damaged to accept an ST needle valve, it will fit at least a #22/.157 drill, or larger (even 11/64"/.171, which is way oversized, but easily available at Home Depot in a fractional drill set). Or, someone took the tang of a file, or a Dremel 1/8 burr, or a 6 penny nail, or something like that, to hack it out without a drill. And if you think I exaggerate, I have seen this done with the tang end of a small file, at the field, stick it in the hole and twist back and forth until an ST spraybar goes through it.
   It's practically impossible to actually fix the crankcase and fit the correct parts with no modifications. But you can put sleeves on the ends of the spraybar that pass through the crankcase to make it fit the bigger hole, without narrowing the part that goes through the center of the venturi. It ends up looking like a dogbone (or like a Fox 35 spraybar), thicker where it goes through the crankcase and venturi, and narrow (.138 ) in the middle. These sleeves have to be secured in place somehow, solder or JBWeld, so they can't slide into the airstream, or fall off and into the engine.
    An alternative is to replace the venturi as well, with a much larger one, to make up for the much larger (.1575"/4.0xx mm) ST spraybar and associated flow restriction. The correct replacement ID  is about .274", and the closest US drill size is a Letter I drill (.272) which will make about a .274 hole. However, if the engine has already been modified, you can probably expect either 17/64 (.265x) or 9/32 (.281x), since letter I drills are rare and many people doing these sorts of modifications probably consider either metric or the decimal system to be a socialist conspiracy, when in fact the metric system is merely a Europhile affectation.
    A .265 is too small and will reduce the performance and invalidate the recommendations on prop and fuel, and require lower-performance props like a 9-5.  A .281 is far, far, too big, and will not needle correctly on any usable stunt prop. If it has a .281 venturi, you probably have to start looking for extraneous head gaskets as well, since the previous owners may have tried to solve their incorrect venturi size by staking head gaskets in. This just makes it worse, but that never stops them. To restore the engine, any extraneous head gaskets must be removed and only the factory stock parts should be used.
     I offer this from extremely painful experience. Since I put people on to the 20FP and "new" 25LA in the first place, I have had people complain on the internet and in person about how it didn't work the way I said it did. In all of these cases, they had *modified the engine*, usually with a f*cking ST spraybar (sometimes in the crudest way possible) left the venturi, and then it won't put out any power - since the venturi choke area is reduced by something like 30%. Tossing the muffler "to save weight" is also a very popular improvement that absolutely destroys the stability of the run.
   I have spares, but you can't fix it, because the hole in the crankcase is damaged by drilling it out and the muffler is in the landfill. A secondary modification, by the real "experts", is to drill the venturi 9/32" (usually while holding it with vice-grips). Then, power is not a problem, it's got too much, can can't be needled, and "runs away". This is invariably "cured" by stacking in a handful of head gaskets, which just makes it run worse. Then you sell it or give it away with a bunch of complaints about idiots from California "who don't know nothin'". Again, you might think I exaggerate, but I have seen this on multiple occasions.
     Another popular improvement is attempting to run a "Real Stunt Prop" like a 9-6, which works with an ST spraybar and stock venturi, but is gutless and no improvement, so you go back to a Fox 35.
Offline Dennis Moritz
« Reply #8 on: August 15, 2019, 12:07:49 PM »
Jim Lee has venturis around .273 for that engine. I’m out of town can’t confirm with my calipers. I know he makes a venturi between the stock FP20 to FP40 offerings. Probably he can cut ones to custom speck.
« Reply #9 on: August 15, 2019, 02:17:41 PM »
Okay, now you guys are really going beyond my knowledge level, but I understand the concept. I'll start by measuring my venturi. Like I said, it ran consistent on my barnstormer, but maybe it was gutless compared to what it could have been. I'll come back to this thread once I get it in the air. I suppose I should set up a test bench someday, but have never done so yet.
Also, I think I have an r/c fp .25 lying around. Is the only difference the venturi and needle/spray bar? If so I could buy the right needle and venturi to get full power.
David
« Reply #10 on: December 28, 2019, 11:15:51 AM »
Okay. I've flown my plane with the to .25 three times now. Motor is inverted. when I ran it a little rich it went very rich on the outsides but stayed good on the insides.
I leaned it a bit on the second flight and it sounded good throughout but I think went a tad lean near the end.
The tank is actually a squishy RC type so I could get a three ounce tank I a tiny compartment.
I didn't have enough power through the square eights. I used a cool looking zingali 9-6 three blade. I'm going to try several 9&10 props today.
St spray bar is still there. Venturi is smaller than 9/32 and bigger than 17/64. I have a micrometer caliper on order.
Plane came out heavier than I wanted. It's my first time spraying dope and sanding. It's 38 ounces.
I have to flip it upside-down to start it.  I've watched plenty of you guys do that, but my first time. A little nerve wracking but so far so good.
Oh, a pretty polished tube muffler of some ßort.
David
« Reply #11 on: December 28, 2019, 11:32:07 AM »
David
   Hi David;
     Sounds like you are in the ball park, and time for fine tuning. This is where patience and attention to small details comes in. That Zingali three blade may not be the optimum choice for that FP-25. They are really heavy and really thick blades. I know the three blade really helps that Flying Tigers look, but if it ain't working right for you, it's not worth it. If you want to try three blades, see what Master Airscrew has to offer in 9 inch diameter three blades. If you have a pitch gauge,, tweak them down to the 4 inch pitch range. They make a 10-5 that works very well for larger bore engines, but would probably be too much prop for an FP-25. I haven't tried one on any of mine yet. But you might try cutting it down to 9 inch diameter or even 8.5". I flew an FP-25 on my Primary Force for a lot of years and optimum prop for it's 45 ounces was the APC 10-4. If you are in the 38 ounce range, try 9-4, 9-5 and the 10-4. I think you will find that the engine will need and want to rev more. If you can not raise or lower the tank to even out inside and outside loops, try turning the cork just a bit in the direction you need to go. If rich on the outsides with an inverted engine, you need to raise the tank, or twist the cork so the pick up tube is raised a bit. You could also lower the engine with some thin shims if need be. What ever changes you make, make them one at a time and try several flights with that change, especially if it seems to improve things on the first try. If things go really bad, go back to your starting point and try again with another change. Good luck with it and keep us posted on results.
   Type at you later and HAPPY NEW YEAR!!
« Reply #12 on: March 07, 2020, 11:14:39 AM »
Hi Gang,
Thought I'd revisit this question. Is an LA .25 RC or an FP .25 simple to switch to C/L? I understand a bit about porting and venting, is it the same? I'm having trouble finding a .25 for under 100, but there are buckets of R/C models well below that. (I don't mind paying over a hundred buck for a motor, but for this plane I'm not so sure.)
Or, is an Enya .29 - 3 worth anything? I won't be able to beat Brett in stunt 25, Lol, but maybe it'll be a better solution.
« Reply #13 on: March 07, 2020, 11:44:52 AM »
Yes.  Put a CL venturi and needle on it and go.  While you're waiting for the CL venturi to show up, wire the RC throttle in place and use that (for CL you'll want to wire it at less than full throttle, or use that pantyhose I suggested).
It's the same as in -- don't do it, don't butcher another poor engine, the 25LA and 25FP work just fine as is.  AFAIK the RC and CL versions are the same, although there were, apparently, an early and late version 25LA, and the later one has more power -- buying used is kind of a crap shoot in that regard.
« Reply #14 on: March 07, 2020, 12:44:16 PM »
Hi Gang,
     The engines are the same except for the venturi/carb. Last I checked, you could still get the venturi. equivalent replacement spraybar/needles are available on eBay, made by Enya in a special run for the eBay vendor. An ST or PA spraybar *is not equivalent*, ir you use that you will have to drill through the case and find a different size venturi.
Online BYU
« Reply #15 on: March 07, 2020, 12:54:04 PM »
Hi Gang,
I'm having trouble finding a .25 for under 100, (I don't mind paying over a hundred buck for a motor, but for this plane I'm not so sure.)
New in Box LA25 Control line version -  https://www.ebay.com/itm/223934353542
New (mounted) LA25 https://www.ebay.com/itm/223930967593
Venturi - https://www.towerhobbies.com/cgi-bin/wti0001p?I=LXCW99&P=ML
Needle valve assy - https://www.ebay.com/itm/OS-FP-LA-20-46-NEEDLE-VALVE-ASSY-DIRECT-REPLACEMENT-NIP/293139719059?hash=item44407d2393:g:M8sAAOSw5eBcolX7
Tags: stunt 25
