  • July 17, 2025, 07:08:07 PM
Author Topic: 25 motor mount  (Read 771 times)
Offline Bootlegger
25 motor mount
« on: November 16, 2019, 11:01:11 AM »
  Guy's I am looking for an O S L A or O S  F P motor mount that can be turned 90 degrees in all directions and match the holes so I can turn the engine in any direction and it match up.
 Does anyone have suggestions as to where I might find one?  Thanks...
8th Air Force Veteran
Gil Causey
AMA# 6964
Online Dennis Nunes
Re: 25 motor mount
« Reply #1 on: November 16, 2019, 11:33:21 AM »
Hi Mike,
I believe you can order Dave Brown products through Ohio Superstar Products website. But this engine mount would require another set of mounting holes to rotate the mount in the other direction.
http://www.ohio-superstar.com/dave-brown-product-line/fiber-filled-motor-mounts
Dennis
Re: 25 motor mount
« Reply #2 on: November 16, 2019, 01:42:39 PM »
  Get a mount that fits the engine then install the hole spacing you need on the back plate. Should be plenty of room to drill the holes you need.
Re: 25 motor mount
« Reply #3 on: November 16, 2019, 08:27:27 PM »
Boots with Legs,
Hmmm....I kind of been thru this recently with this exact mount. The hole pattern in the Dave Brown mounts is trapezoidal, so you can forget about just rotating the mount. In my prior post about the Red 'Pants OPP (Other Peoples Planes--Fancy Pants) I went thru the whole deal. And, the reason that rotating around is impractical is because of the change in the spraybar location with respect to the tank. Again, if this is of interest, go find those posts....
As far as the idea that you can "install the hole spacing you need on the backplate" I'd say check that idea very carefully before you plug the drill in. It did not look feasible to me--or I would have done it.
I also have an igNoblarf OPP which came to me second hand with a Dave Brown mount. The holes in the firewall were in the wrong place vertically for the tank run to ever work. (Flooded the engine if you tried to invert the plane.) So I made a butchplate out of plywood to convert one hole pattern location to another that worked. So a hole pattern with clearance holes for countersunk screws that matched the existing firewall pattern, and a second pattern that matched the DB mount and had blind nuts and which translated the pattern vertically until the tank centerline was lined up. That worked out very well, so maybe the same idea would allow you to do whatever it is you are trying to do...? I can send a photo if that helps explain it.
I thought I remembered a square-backed mount, might have been metal, and maybe the pattern was symmetric in both directions. I looked in the OS accessories and didn't see it. Maybe a Tatone or a Craft Hayes?  You can check MECOA for these.
The Divot
Online Brent Williams
Re: 25 motor mount
« Reply #4 on: November 16, 2019, 11:29:41 PM »
OS71908100 has a square mounting pattern for OS 20/25FP, 25LA.
https://www.ebay.com/c/1124598321
Re: 25 motor mount
« Reply #5 on: November 17, 2019, 12:16:41 AM »
Brent,
You're a man of much Google talent....
The Divot
