Wing is 34 x 8 , sitting back 6 inches from end of fuse. Engine mounts are offset about 10 degrees. After mounting the engine we rubber banded the wing and moved it around to get a usable cg, which is now 2 1/4 inches from le, slightly nose heavy but that is what we wanted. Overall length is 26 inches and fuse is 3 inch wide 1/2 inch balsa. We used 1/8 in. ply top and bottom from nose to end of wing and 1/2 x 3/8 maple engine mounts. Stab is 2 1/2x12 inches and elevator is 1 3/4 x 12. Cloth hinges and 1/8 wire pushed thru holes in the plywood and bent for landing gear. Lines are 52 x .012. Seems very durable and i would think any engine from .15 to .25 should work.
