  • July 22, 2025, 06:40:49 PM
Author Topic: BOLLY PIPE FOR PA .61  (Read 864 times)
Offline Claudio Chacon
« on: October 19, 2020, 08:34:46 AM »
Hello guys! The pipe I've been using (Brian Eather) during the last 10 years or so with my PA .61 needs to be replaced.
A local hobby shop here in Argentina stocks a Bolly Pipe (the one you see in the pic) and the dimensions are:
*Total length: 495 mm.
*Max. diameter: 36 mm.
*Min. diameter: 16 mm. (at the inlet)
Do you think that this pipe will be OK to use with my PA .61?
Any help will be much appreciated...
Thanks a lot in advance!
Offline Craig Beswick
Re: BOLLY PIPE FOR PA .61
« Reply #1 on: October 20, 2020, 04:53:46 AM »
Is Brian out of all his pipes?
Craig
AUS 87123
"The Ninja"
