  • June 27, 2025, 10:32:47 AM
Author Topic: Metal backplates  (Read 3304 times)
Offline cory colquhoun
Metal backplates
« on: August 18, 2018, 10:31:40 PM »
Hi, does anyone know where I can get metal backplates for la 15 & la 46
 Cory
Offline James Holford
Re: Metal backplates
« Reply #1 on: August 18, 2018, 10:36:02 PM »
 Cory
I been robbing them from busted .40fp cases :)
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
« Reply #2 on: August 18, 2018, 10:39:20 PM »
ok, thanks ,I’ve been trying to contact mr Shipp but he mustn’t be doing them anymore
cory
Offline Phil Krankowski
« Reply #3 on: August 19, 2018, 07:01:22 AM »
The LA and FP have the same bolt patern and diameter, but a different amount of material inside the case.  Check before doing that swap.
Phil
Offline George Albo
« Reply #4 on: August 19, 2018, 09:14:12 AM »
Curtis Shipp has back plates for the OS 46La  available  at $12 each. $3.00 shipping   1-100.
I ordered 6 for my engines not too long ago.
Here's his email:  m14m21@bellsouth.net
Offline gene poremba
« Reply #5 on: August 19, 2018, 12:47:07 PM »
 I am in need of 6 myself! I have sent PM's to Randy Smith and Curtis Shipp with no reply......Gene
« Reply #6 on: August 19, 2018, 03:21:52 PM »
This is the problem I’m having ,been sending Curtis emails with no reply,
Online john e. holliday
« Reply #7 on: August 19, 2018, 03:54:49 PM »
Hey he has a business and gets busy some times.  I know when I ordered mine it was several weeks before I got a response to a PM(private mail).  hey are worth the wait. H^^
Dennis Leonhardi
« Reply #8 on: August 19, 2018, 05:33:04 PM »
Backplates for the Magnum .15 GP, Thunder Tiger .15 GP, OS .15 FP and LA are interchangeable.  An individual on eBay offers a wide selection of laser cut gaskets - great product, great service, very reasonable prices.
Dennis
« Reply #9 on: August 19, 2018, 05:36:52 PM »
The only backplate I found that isnt interchangeable with the Thunder Tigers is the .25 backplate on a .25LA. Doesnt fit all the way on the case.
But the .40FP backplate fits perfect on a .46LA.
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #10 on: August 19, 2018, 05:37:58 PM »
Dennis
Yep.. even offers allen head screws and gaskets as a package set if desired too.
Jamie Holford
Lafayette, La
AMA #1126767
Offline dennis lipsett
« Reply #11 on: August 19, 2018, 06:07:54 PM »
I think that this is the source that your mentioning
http://icbimproducts.com/gaskets/newcart/index.php
Dennis
Dennis Leonhardi
« Reply #12 on: August 19, 2018, 07:17:52 PM »
Dennis
Yes, I've ordered dozens of sets from him and recommend him highly!
Another Dennis (the Menace)
 y1
Offline BYU
« Reply #13 on: August 19, 2018, 11:16:48 PM »
He is making a new limited run now and is shipping very soon, and yes, he does run out of them.
Offline Dallas Hanna
« Reply #14 on: August 20, 2018, 06:46:12 AM »
 Cory
Cory, pm sent.
H
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #15 on: November 18, 2018, 08:45:16 PM »
Hello
Has anyone tried a Thunder Tiger Gp 42 back plate (part AA0576) in a LA 46? They seem to be the same as the old OS FP40 backplate and are still in production.
Busted a back plate on the weekend when a loose tank started a vibration that loosened things up and took off the metal N/V bracket and part of the backplate with it!
Thanks Gerald
Offline Richard Imhoff
« Reply #16 on: November 19, 2018, 01:36:32 PM »
Bolt pattern matches up but the outside diameter is about 60 thou to big. An easy fix with a small lathe
 I sold a bunch of them awhile back but no longer can get them "tower don't handle them any more" Cost was cheap at less the $4 bucks.
I don't use a metal plate on the LA's any more I cut an o ring groove and they seal up just fine, but you do need a lathe to do it
Dick Imhoff  AMA 58502
Combat, Racing, Stunt, and big time fun flyer, and Maybe a bit of carrier.
« Reply #17 on: November 19, 2018, 02:26:42 PM »
Thanks Richard, I will give the O ring groove a go on a new plastic backplate. Did find an old Magnum GP44 backplate fitted the LA 46 as well but it has a large piston cut out I presume for the greater stroke (the GP44 is rare too).
Regards Gerald
