I guess as with a lot of things, "it depends" on your plane, how well you know your plane, and how strong the wind is. If it's a trike plane, where is your C/G, small rudder, huge rudder, does it have more side area aft, or middle, is it a feather weight or a sled, etc. You just have to get a feel for what is best for you.
But... as a general rule, I'll start at 5 o'clock in light winds, and get closer to 6 gradually as the wind grows stronger.
Another important thing to keep in mind is technique. If the wind is howling, you just can't plant your feet and wiggle your wrist and hope for the best. I always will take several small steps back in a sweeping arc to whip the plane off the ground and maintain total control, and keep the elevators neutral until the plane is actually moving at a decent clip. Not easy to do and get that perfect smooth takeoff, but you can come really close, and it beats the heck out of grinding your carbon prop down to a nub if you let the wind get under your tail.
Another aspect to keep in mind is your WHEELS!!!! Sloppy wheels can pigeon toe and nose the plane over in wind, or, if you whip it off the ground like I do, excessive slop in the wheels can bind when you side load the plane with line tension as you whip it and cause the same problems. Best to have the inside wheel set to just roll freely but no slop, and the outboard wheel to spin just slightly less freely, but still free enough so that when you flick it with your finder it goes around a couple turns and comes to a stop.
Lastly is your human stooge. Dale Barry showed me proper launch technique in the wind at the Nats one year... and it works. Never ever lift your hand abruptly vertical over the stab when letting go of the plane, just keep your hands on the same level as you let go and don't jump up, stay still a second and keep acting as a block to the wind on that tail before getting up...
(I hesitate to advocate this because not everyone is in shape or coordinated to do this)... but better still if you are flexible enough, assuming you hold one hand on the wing LE and the other on the stab, drop your wing hand to the ground to support yourself as the plane rolls out and lean forward and follow over the stab with your stab hand at the same level above, not touching, not rising, just parallel, and keep it from popping up for the first foot or two. I've lost count of how many times my palm has been slapped by a stab like that on a windy day, which would have otherwise been a ruined carbon prop at a contest on windy days. Thanks for that one Wizard! I hope my back holds out to keep doing this because it really works.
Well, that's my .02 with inflation FWIW,
EricV
