  • July 20, 2025, 03:29:11 AM
Author Topic: National Balsa  (Read 1358 times)
Offline James Mills
National Balsa
« on: May 15, 2013, 09:49:03 PM »
I was looking on the National Balsa site and was wondering if the Aero Lite Balsa is contest grade or do I need to specify?
James
AMA 491167
Offline Dave Denison
Re: National Balsa
« Reply #1 on: May 15, 2013, 10:52:29 PM »
James
The National Balsa Co. supplies some of the best graded balsa to be found.  Yes, to your question the Aero Lite IS ALL super light and fine quality.  Their prices and delivery times are great also.
ama 41041
Offline James Mills
Re: National Balsa
« Reply #2 on: May 16, 2013, 08:26:22 AM »
James
Thanks.
James
AMA 491167
Re: National Balsa
« Reply #3 on: May 16, 2013, 11:09:33 AM »
The "bargain" grade from National, either regular or "lite" is good wood.  However, Many of the balsa sheets are not straight. So, it is often necessary to put a 36" straightedge along the edges and cut straight down the length.  This uses up maybe 1/8" , but the result is a light and flat piece of balsa.
Of course, this isn't necessary if you are cutting ribs or small parts.
Re: National Balsa
« Reply #4 on: May 17, 2013, 05:46:35 AM »
No matter the company, SIG,  Lone Star or even National Balsa I have yet to find every piece as straight as we would like it.   Only time to worry about it being straight is leading/trailing edges and the fuselage top line.   I also think the lighter the balsa the worse it gets.  My opinion. D>K
Offline Joseph Patterson
  • AMA member- Supporter
Re: National Balsa
« Reply #5 on: May 17, 2013, 08:28:52 AM »
   While on the subject of Balsa has there been any new info about Lonestar.
     Doug
