On Low scoring:
By now everyone has figured out who the low scoring judge was. Before getting upset about how low I scored your flight, I suggest you take a look at other pilots score sheets. Jose, take a look at Paul Walker's Friday's first round flight scoresheet and compare it to yours! You'll stop talking about "halo" effect or predisposition of scoring "elites" higher than the rest.
Jose, I consider you a friend and I would feel like sh$*t if I was not fair to you in scoring. I was genuinely rooting for you but you gave up points on every maneuver. Your second flight was and order of magnitude better than the first one! You looked like Paul Walker: instead of getting upset about the bad flight, you regrouped and were kicking butt. It was not your ability to step up and put up a great flight that kept you from the top 20. It was the equipment
Re: 2013 Nat's coverage!
« Reply #498 on: July 29, 2013, 11:27:38 AM » Quote Modify Remove
________________________________________
Posting my scores from first round qualifying at 2013 Nat's
the score sheets clearly show the disparity in scoring and illustrate with actual numbers the discussion above.
After first round flight I had Doug's response WTF to do now. Fly for the judges that scored me high or modify to please low judge.
i was down 10 points after one flight. the spread are 96 and 70 Pt's between high,mid and low judge.
Low judge even wrote comments on my score sheet, a first for me,15 national 6 team trials.
I did not include the judges names
Jose Modesto
Re: 2013 Nats coverage!
« Reply #500 on: July 29, 2013, 12:07:53 PM » Quote Modify Remove
The comments were on my first flight of first day. Second flight has a story behind it. Look for it in electric section soon. Others flyers received notes for both flights.
Hey missed you at Nat's this year. Hope to c u soon. The Texas boys did a great job filling in for you.
Jose Modesto
2013 Supporter
Trade Count: (0)
Captain
Rate User 17
Online
« Reply #504 on: July 29, 2013, 02:22:20 PM » Quote Modify Remove
Posted to show numerically the discussion started by Ted F. Doug posted a letter grade scoring system were my scores can be converted to letter grade.
I know that the low score were not a personal bias but a pattern interpretation difference. Another flyer in my group scored 5 points lower from low judge yet average 5 points higher than my average score. His disparity in points were even larger than my score.
Jose Modesto
Steve. You have attributed to me words in quote that were never said by me.Above are ALL MY POSTING ON THIS SUBJECT. NONE OF THE WORDS THAT YOU ASSIGN TO ME IN QUOTES ARE IN MY POSTINGS. Please correct your post and retract your false assertions of my views by your use of words in quote.
I must also correct two other FALSE assertions.
1)You posted that I had never made the top 20(electric forum) false 2010 Even Led a round as an UN ranked circle fill in.
2) That my motor overheated on second flight FALSE I set timer to 2 min. thus when the motor gave me the shut off warning I waved off the rest of the Flight. Then I landed. The chill that I felt when I heard the cutoff warning and realizing that I dint reset the timer. (there is a story behind this) MY GRAVE ERROR, your first round low score would be meaningless with out my blunder. Your assertion that my equipment prevented me from reaching the qualifying round is NOT CORRECT.
After first round and comparing scores with guys in my group,I understood that you were really low scoring across the board. (all flyers) See My underlined comments above
Your scoring methods came into question by fellow judges. Mr. Fancher also in this thread questions not YOUR ABILITY TO SEE ERRORS BUT THE VALUE YOU ASSIGHNED TO THE ERRORS. Your scoring was overly harsh to minor errors.
One Area that you mentioned can't be questioned,NATS PREPARATION. You can't go to Nat's with hopes of winning without extreme preparation. Flew model for fist time morning of appearance judging.
I WATCHED Every flight of the top Five and I cant imaging how to separate the #1 and 2 pilots. The styles are diametrically opposed Doug slow with the stop and go corner beautiful ,aggressive,small, smooth ballet.
Then Paul Aggressive ,Faster ,Harder with blinding corners MMA at 70 feet.
The finals judges also had a hard time separating those two by the final score.
I would like to express my thanks to all those guys and gals that VOLANTEER so that I can compete in the Best US contest at the best site to fly CLPA.
With all the respect in the world I Thank you guys.
Back to Steve you must at some level ask your self was I overly aggressive in my scoring in Comparison to extremely season NATS level judges. Only you can answer.
You and I must Meet at the end of 70 of wire and resume this discussion while doing the tricks that make this so enjoyable.
Jose Modesto
