  • July 12, 2025, 03:22:57 PM
Author Topic: 2011 New ride  (Read 829 times)
2011 New ride
« on: February 11, 2011, 06:37:03 PM »
I put some details of my new Raptor model for 2011 in the Building section but not everyone reads that section - So here is a little taste. This is the second model. First one was posted a few weeks ago. In clear - this is my Nats edition
You can check out full details over there
http://stunthanger.com/smf/index.php?topic=20477.0
The photo below was taken about 5 weeks ago - Im getting closer to paint every day. - Yes that is a foam sanding block holding up the tail... Its not a new feature I just hadnt installed the removable tailwheel assembly yet. Im using the Yatsenko system. Just needed to elevate the rear to get stance and Photo op.
I hope to have it in primer within the next few weeks. Paint due to finish late March with test flights shortly after leaving Aprl May June for final commission to comp spec.
« Last Edit: February 11, 2011, 07:03:50 PM by PJ Rowland »
Re: 2011 New ride
« Reply #1 on: February 11, 2011, 07:21:57 PM »
THAT looks really good to my aesthetic sensibilities. Sorta like Gieske Nobler meets SV-11. Green and Gold? Good job, Mate!  H^^ Steve
« Last Edit: February 12, 2011, 09:13:54 PM by Steve Helmick »
Re: 2011 New ride
« Reply #2 on: February 11, 2011, 07:58:07 PM »
Will white with Tiger print and weathered panel lines - Same as the previous but ive done alot more work on the weathering technique
