Interesting.
I've been looking at the MKI version of the plans, and I see how the flaps are built like the ailerons on a typical R/C aerobatic model or sailplane. It makes me wonder why this is so rarely done.
A typical control line stunter starts with a conventional symmetrical airfoil then the trailing edge is cut off, and flaps are attached to the trailing edge. The airfoil that results, when the flaps are considered, is NOT a NACA 0018, or whatever other airfoil that was started with.
You rarely see ailerons/flaps like that on R/C aerobatic planes, and never on a sailplane. The flying surfaces on those models are part of the airfoil, not an after thought simply hinged onto a blunted trailing edge.
It makes me wonder if this is done just because it's easier and works OK, or if conventional ailerons operating as flaps on a UC model have been found to be less effective.
