  • June 25, 2025, 11:49:10 AM
Author Topic: which engine for a ARGUS  (Read 1364 times)
Offline Alan Buck
« on: March 12, 2007, 06:24:05 PM »
I Have a are tiger 36, mag 36,la40, and fox 35 . Not against a Brodak 40 or DS 40 thanks Alan
ALAN E BUCK
Offline Bootlegger
Re: which engine for a ARGUS
« Reply #1 on: March 12, 2007, 07:14:16 PM »
 Im have used an LA 40 in a lot of models and enjoyed the service I got.
 I also use a LOT of OS 32 SX's with a "Hemi" head and blocked boost port.
 You do have a good selection... Now I have a question-----which engine do you like best ???
  I think that is the one to use... H^^ D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: March 12, 2007, 09:35:13 PM »
Hi Alan,
I have flown mine with a DS 40, L&J Fox 35 and a retimed Werba 32 (used that one at Brodak's).  The DS 40 and Fox 35 seem best suited to it.  I used shaft extensions on both and they balanced perfectly with out added weight to the tail.  Both pulled the plane with no problem (36 oz) at Huntersville. (turbulence)
The Aero Tiger would be outstanding, but you will have to add weight to the tail.  Same with the others.
I am putting the L&J Fox 35 back into it, as of Sunday night. (Had to do some repairs!)
P.S. The DS 40 needs a venturi in the 295-300 range (we found this out), and three head shims total (from Tom's directions) for 5%-10% nitro.
Bill <><
Offline Bob Zambelli
« Reply #3 on: March 13, 2007, 05:17:39 AM »
   SAITO .30!!!!!! #^ #^ #^
