  • June 15, 2025, 11:01:03 PM
Author Topic: 20 lb test lines  (Read 1130 times)
Offline Bootlegger
20 lb test lines
« on: May 30, 2021, 05:11:49 PM »
 Tried the search for hi vis yellow 20lb lines, were they Power Pro or what and where can I get them??    Obliged...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline kevin king
Re: 20 lb test lines
« Reply #1 on: May 30, 2021, 07:19:29 PM »
There's some info here that may help. I asked the same question on the Cox engine forum, and this guy swears by them. The reply quoted is from londke3:
Quote from: londke3
Quote from: kevin king
Hello, is there a part # or exact name and type of line that you recommend for 1/2a planes? I would like to know what size to get for a heavier 1/2a stunt plane powered by a TD 049. I would like the line length to be 42' also. How are these PowerPro lines compared to steel 008 lines? Is there any performance loss? I would appreciate your thoughts and recommendations! Thanks! Kevin K.
We are currently using PowerPro 40lb Hi-Viz yellow for our 1/2A combat planes at 42' length. We use the 40lb because it still has to measure .012 like steel for combat use in competition. If you are just sport flying 1/2A stuff you can easily use the 20lb or 30lb and still be safe. Original Power Pro is great but they now have Power Pro Maxquatro which is 25% thinner than original but with the same rated break strength.
« Reply #3 on: May 31, 2021, 01:39:52 AM »
I have been happy using PowerPro 30 lb test. Have used it for various planes, but probably the one of most interest was on a Lil Satan with a strong reedy Mouse Motor. The very approximate diameter of these was around .012 inches.
I found that white was plenty visible enough on grass or asphalt.
Good luck with yours,
Offline John Park
  • Agricola
« Reply #4 on: May 31, 2021, 04:37:59 AM »
The stuff I'm using over here in England is Power Pro hi-vis yellow, 15 kg (33 lb.) with a quoted diameter of 0.23mm (approx. 9 thou.).  I'm using it at 35ft. for 0.75cc diesel and 45ft. for 1.5cc diesel sport/stunt models, with perfect satisfaction.
Offline Bootlegger
« Reply #5 on: June 13, 2021, 11:19:56 AM »
 Brent Williams do you have a phone number for contact for these lines?  Much Obliged   #^   :)!
Gil Causey
AMA# 6964
Offline Fredvon4
  • Central Texas
« Reply #6 on: June 14, 2021, 06:13:19 AM »
Gil click on any of the links and there is almost always a CONTACT US link with addresses, e-mail, and phone numbers for sales or customer service
Fred von Gortler IV
Offline Bootlegger
« Reply #7 on: June 15, 2021, 10:18:39 AM »
 Thanks Fred, your adivse was spot on I looked and saw a phone number, need to get some glasses  thanks again
Gil Causey
AMA# 6964
