  • June 28, 2025, 08:46:36 AM
Author Topic: blank  (Read 1595 times)
Online Motorman
blank
« on: October 23, 2013, 11:08:56 AM »
blank
« Last Edit: September 21, 2021, 06:18:40 PM by Motorman »
Re: 2 Blade to 3 Blade Conversion
« Reply #1 on: October 23, 2013, 02:28:45 PM »
I don't think there is any way to directly convert as you are wishing.  There are quite a few aspects of a prop that affect its performance;  blade shape and width, thickness, helical pitch, flat or under cambered, tips square or round,  what engine...... Given what little you really have to start with I guess I would start with 10" diameter since I'm adding a blade then use about the same design and pitch you have now.  It will still be a completely different prop but in carbon you will heat and re-pitch the blades anyway if its not on the money.  Make a number of them so you can modify the tips, etc., to experiment.
« Reply #2 on: October 23, 2013, 05:42:16 PM »
You can get a clue from Javafoil,  http://www.mh-aerotools.de/airfoils/javaprop.htm , or from this paper: http://arc.aiaa.org/doi/abs/10.2514/6.1983-190 .  What powerplant do you have that works at less than 9570 RPM?
« Reply #3 on: October 23, 2013, 10:23:26 PM »
Merely plugging numbers into a program that somebody else already wrote "drags down" an iterative process of making molds for three-bladed unpitchable propellers for a unique RPM range?
« Reply #4 on: October 23, 2013, 11:28:32 PM »
Power is E flight power 15, thanks for the links but all that heady engineering stuff just drags down my process. I wanted to get pretty close on pitch because you can't re-pitch the props I make after they cure for some reason, not going to copy APC anyway. Did Tornado make a 10x6 and a 10x4?
Oh Holy Cow!  Why not just use and old fox 35 and a 10-6 Top Flite prop and forget about all this "heady engineering stuff"...if you want 1958 technology why not just use it!  LL~ LL~
 LL~ LL~
Randy Cubery
« Reply #5 on: October 24, 2013, 02:14:51 AM »
Yes, and they produced a 9-6, all three blade props.  I have seen some carbon copies of the 10-6, but do not know who did them.
« Reply #6 on: October 24, 2013, 05:10:59 PM »
 That would be Steve Wilk, Eliminator Props, here in the Vendor section.
