Thanks Tim. After thinking about it, I put the micro switch in the lead to the points which carries very little current since it is only operating a transistor, but does fluctuate a lot as the points open and close. I will have to go to Igor's site and read up on the operation and see if it can be moded to work for me. Maybe I can get a few more guys flying ignition. Sparky engines are very tempermental on fuel load as to timing advance and needle setting.
I had a super high flight at VSC a few years ago but ran over on gasoline by 8 seconds. I had let it set on the black top for about 5 minutes full of gasoline, and it flooded itself which cost me a full minute in starting. I have learned to start them and shut them off before giving the hand signal to start, and then they always start right back up. Usually not necessary, but it never hurts. Most times I can start them on the first or second flip.
