  • July 11, 2025, 07:57:52 AM
Author Topic: 2" mistake  (Read 2805 times)
Online EddyR
2" mistake
« on: September 20, 2015, 03:30:58 PM »
 I just finished my Bearcat and did not make any major mistakes on it. The Rabe Bearcat that I built a few years ago I made some huge mistakes that added a lot of weight. About a year ago I started a Jamison from plans. It is a very easy model to build. I lost interest several times but finally covered it with silk a month ago. Two ribs collapsed and I repaired it but did a poor job and hated it. Last week I removed the silk and today I was going to cover it in paper.  I cut the paper and on outboard  wing panel the paper was to short? I measured the wing and I had built the outboard wing 2" to long. If It had been the inboard wing I would have lived with it. I cut off the extra panel and attached the wing tip and now it has the correct wingspan 50". That is a first for me. It has been hard to stay interested in any model for a long time as age and other interest has taken over. I will cover it tomorrow and get the thing done finally.
 Tell us about your big mistakes.
Offline Target
  • C/L Addict
Re: 2" mistake
« Reply #1 on: September 20, 2015, 03:34:28 PM »
I was told on my first ever build that the wing tip weight box actually goes on the BOTTOM of the wing, not the TOP like I did it.
Ooops.
Now I know. ::)
R,
Chris
Chris
AMA 5956
Re: 2" mistake
« Reply #2 on: September 20, 2015, 04:06:41 PM »
Like wood working and construction work you learn to cover up or work around the mistakes.
  • Gravitywell
Re: 2" mistake
« Reply #3 on: September 20, 2015, 04:59:52 PM »
I built a Veco Squaw years ago from plans.  It was my very first plans built plane.  Yeah....the outboard wing was 2" longer than the inboard and I also had to take the wing apart cause it was upside down. HB~>
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Re: 2" mistake
« Reply #4 on: September 20, 2015, 07:10:54 PM »
Most of my mistakes have been gluing the motor mount on with the motor on the left(unintentionally).  Much less of a problem now with metal mounts.  I still do it but it's easy to unbolt the mount and flip it over.
Re: 2" mistake
« Reply #5 on: September 20, 2015, 08:23:59 PM »
A few years back...very late one night I very carefully jigged up my KA10 that was under construction to install the stab with 3/4 of a degree of positive incidence.  after working hard and getting it exactly as I wanted it in all planes, I patted myself on the back and went to bed.  The next day, wide awake, I went to the shop to admire my handiwork and instantly realized that the airplane was, of course, jigged upside down so my positive incidence was very negative...It really is hard to cut one of those dam things out without destroying the entire fuselage.  I probably invented some new words that morning...at least my wife said she could hear me all the way in the house but couldn't really tell what I was yelling!!
Offline Dane Martin
  • heli pilot BHOR
Re: 2" mistake
« Reply #6 on: September 20, 2015, 08:55:58 PM »
When i was building my triplane, i read the plans wrong, or built the center wing over the plans upside down. The bell crank was supposed to be outboard and the push rod exits the bottom. Well it ended up inboard, exits top and attaches to the elevator on top! I didn't even realize what i had done until looking at the pics after flying it. I thought, wow, that push rod looks weird.
Offline Will Davis
Re: 2" mistake
« Reply #7 on: September 21, 2015, 02:58:46 AM »
A couple years ago , right before the KOI , I needed a new tank for the skydancer, bent up the metal, shaped end caps , fixed vents and pickup, went to put in the plane and it was built upside down,vents on wrong side ,  hope I never do that again
Will Davis
"Carolina Gang"
Offline John Park
  • Agricola
Re: 2" mistake
« Reply #8 on: September 21, 2015, 07:12:09 AM »
My scrap-box still contains a left wing for a free-flight rubber model, laminated tip and everything - a nice job, some of my best work.  Problem?  I'd already built the left wing, and this one should have been its mirror image...
Offline john ohnimus
Re: 2" mistake
« Reply #9 on: September 21, 2015, 07:47:58 AM »
Let's see....
 Just had finished gluing the wing halves together on my Prowler, and my buddy Bill Knigge say's "Hey man I didn't know you flew clockwise"... ARGH!!!!
Hard Tellin'....  Not Knowin'
AMA 413710
Offline badbill
Re: 2" mistake
« Reply #10 on: September 21, 2015, 08:48:07 AM »
Plenty of control line models are designed to have one wing panel longer than the other. You sure it wasn't designed that way?
Bill Davenport
AMA 28141
Offline John Park
  • Agricola
Re: 2" mistake
« Reply #11 on: September 21, 2015, 09:20:32 AM »
If it was, the outboard wing ought to be the inboard wing, so it's still a mistake...
Offline Ward Van Duzer
Re: 2" mistake
« Reply #12 on: September 21, 2015, 10:37:18 AM »
Many years ago an old New England carpenter once made this admonishion to me, (You need to add the NE accent here!)...
Measure twice, cut once!
Ward-O
Offline Warren Wagner
  • Bradenton, FL
Re: 2" mistake
« Reply #13 on: September 21, 2015, 06:16:18 PM »
Eddy,
Wow....look at what you started.   You have lots of company.  :-)
Warren Wagner
Warren Wagner
AMA 1385
Offline Gene Martine
  • Started flying 1952 (AMA 2903)
Re: 2" mistake
« Reply #14 on: September 27, 2015, 08:21:11 AM »
