  • July 04, 2025, 01:24:30 AM
Author Topic: Cox .049 cross breed  (Read 1323 times)
Offline Bootlegger
« on: November 30, 2017, 09:48:26 AM »
  Some where on Stunt hanger  I read about exchanging T D .049 engine parts with Medallion .049 engine parts and getting a super .049 stunt engine.
  However looking in the search box I couldn't find this info.  Who can help?  Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Cox .049 cross breed
« Reply #1 on: November 30, 2017, 10:10:06 AM »
Not sure what discussion you were looking for, but just the day before yesterday I was talking with a co-worker about taking a TD .049 and pulling the venturi body and replacing it with the venturi body from a Medallion .049.  Talking to others in the past, the thought is that you get the more aggressive porting of the TD with the better fuel suction of the Medallion.  Power might fall somewhere between the two.  I've never done it before, but I was ordering parts from MECOA a couple of weeks ago so I ordered and extra Medallion body to do the experiment.  Maybe this is what you're thinking of?
Mark
Offline Garf
    • Hangar Flying
« Reply #2 on: December 05, 2017, 03:20:27 PM »
I did this to a TD .09. Installed the venturi body body from a medallion .09. No need to change the shaft.
Offline Larry Renger
« Reply #3 on: December 05, 2017, 04:50:07 PM »
I keep the Medallion lower end stock and add a TD p/c and Merlin plug head.
Offline Bootlegger
« Reply #4 on: December 06, 2017, 09:04:03 AM »
  Larry I sent you a P/M..
Gil Causey
AMA# 6964
