  • July 19, 2025, 04:33:08 PM
Author Topic: 11/5 3 blade?  (Read 1424 times)
Dwayne
11/5 3 blade?
« on: October 06, 2010, 07:26:56 PM »
I've looked everywhere I can think even googled it, where can I get a 11/5 3 blade.
Re: 11/5 3 blade?
« Reply #1 on: October 06, 2010, 09:01:29 PM »
May try here.
http://masterairscrew.com/3-bladeseries.aspx
Not a 11/5 but I am not sure an 11/7 is really a 7in pitch.
Dwayne
Re: 11/5 3 blade?
« Reply #2 on: October 06, 2010, 09:29:43 PM »
Thanks for the reply but I just remembered Zinger...Bingo!  y1
Re: 11/5 3 blade?
« Reply #3 on: October 08, 2010, 12:15:58 PM »
The Master Airscrew checks out at around 5.5 on a pitch guage.  MA appears to use the chord line of the airfoil for pitch, not the flat on bottom of the airfoil.
Dwayne
Re: 11/5 3 blade?
« Reply #4 on: October 08, 2010, 04:15:27 PM »
Thanks that's good to know I was going to order a 12X4.5 from Steve Wilks and cut it down as the one from Zinger kinda looks heavy. Anyway what I'm doing is mounting a LA 46 upright with with wing mounted landing gear so ground clearence may be an issue.
Dwayne
Dwayne
Re: 11/5 3 blade?
« Reply #5 on: October 08, 2010, 08:11:25 PM »
Sheesh I knew it was out there...lol Not quite a 11/5 but close enough.  y1
http://www.evolutionengines.com/Products/Default.aspx?ProdID=EVOE100P
Offline Ward Van Duzer
Re: 11/5 3 blade?
« Reply #6 on: October 09, 2010, 10:45:34 AM »
Before we discovered Bolly props (and their adjustability) the "pipe players" "carved" their own custom props from existing stock. We scraped the trailing edge of the backs of the prop blades with the sharp edge of a straight cut piece of glass, or a # 26 Xacto knife. Do this until the 5 inch pitch measures 4.5, 4.75 or whatever...Then refinish.
FWIW
Ward
Dwayne
Re: 11/5 3 blade?
« Reply #7 on: October 09, 2010, 08:41:15 PM »
Thanks Ward it may be about time I learned how to do that, how did you know what the pitch was? Is this what you used?
http://www.greathobbies.com/productinfo/?prod_id=RVO1008
Dwayne
