General control line discussion => Open Forum => Topic started by: Bootlegger on February 06, 2014, 02:03:17 PM
When you thin carpenter glue, how much do you thin it? I'm talking about for construction of model wings and such.
I want to get good glue penetration, and have a good (strong) glue joint.
I haven't heard of anyone thinning it. Titebond (type 1) is fine as it comes out of the bottle.
Water or rubbing alcohohol will work.
Thanks John and Brett, I have been using it straght from the bottle, but didn't know if there was abetter way.
Thanks again...
I thin Titebond Wood Glue with a few drops of water. I thin enough to let me apply it w/ a syringe (no needle). It wicks nicely into the joint and cures.
Play around with some experiments and you will see the viscosity you like.
Hope this is helpful
Jim Hoffman
I thin titebond when laminating wood. 4 parts glue to 1 part water ... it spreads evenly that way.
I also thin Titebond for some applications. You are in the ballpark with 10% water, no more than 20% max or you might start to weaken its bonding strength.
If laminating with Titebond works for you...so be it. However I would not recommend laminating with it as it usually take an Eon to dry inside large areas and results in serious warps! Believe me I know!
Again thanks Men, Randy I don't plan to laminate with it, just want good joints at ribs to spars and such.
Allan, if the weather ever breaks we need to do some flyin'..
I flew last Saturday and the Sunday before that. Weather is looking good for this coming Sunday again. Have to take advantage of any decent days that come along this time of year. Me and at least two other local flyers will be at the NOLA field Sunday starting around 2pm, in case you wanna come down for a visit.
Here's a suggestion, Gil. Crick on the link. H^^ Steve
http://stunthanger.com/smf/index.php?topic=33900.0 (http://stunthanger.com/smf/index.php?topic=33900.0)
I double glue with thinned Tightbond. I thin it just a little, till it has a little run to it. I paint that on and let it almost dry. It penetrates the wood very well. Then re glue with full strength Tightbond. The second application of glue re wets the first. I get some really good and strong joints this way.
I am now using less epoxy and less CA glue. Saves $$ and maybe a bit of wight.
