  • July 05, 2025, 01:47:21 AM
Author Topic: ..Math..  (Read 2118 times)
Offline Bootlegger
..Math..
« on: November 30, 2013, 06:24:43 AM »
  What is the formula for figuring venturi size when the spray bar is .159, or what ever size and goes thru the venturi ?
  Thanks for your help...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Akihiro Danjo
Re: ..Math..
« Reply #1 on: November 30, 2013, 06:45:13 AM »
Math professor is here  :)
Aki
http://www.nclra.org/Programs/Venturi.php
Offline Gordon Tarbell
Re: ..Math..
« Reply #2 on: November 30, 2013, 07:06:02 AM »
Venturi sizes are best compared by way of square area. This is how I do it.  Measure the dia. of the venturi at smallest point , called the vena contracta if I remember my 7th and 8th grade latin,(this should also be where the spray bar goes through). Let say it measures .250" , plug it into this formula  .250X .250 X .7854 = .0490875  this is the area of the venturi , now multiply the dia. of the spray bar .159 by the dia. of the venturi .200 (.159X.200 = .0318 , this is the square area of the spray bar.  Subtract the square area of the spray bar from the square area of the venturi and this give the effective area of the venturi.    .0490875 - .0318= .0172875 area in square inches. this gives the effective dia. of .1485 for the venturi. if there was no spray bar going through it.  It can be calculated more accurately to allow for the radiused ends of the spray bar but for what we are doing it is close enough. I am not good at typing math so I hope you get the drift. Find the area of the venturi then subtract the area of the spray bar to get the effective area of the venturi/spraybar combo. Then you can conver the square are back to effective dia. to compare to a set up that does not use a through the venturi spray bar setup.
Gordon Tarbell AMA 15019
Offline BillLee
Re: ..Math..
« Reply #3 on: November 30, 2013, 11:44:24 AM »
Or do what was suggested earlier:  http://www.nclra.org/Programs/Venturi.php
Example for a .312" venturi and a .159" spraybar:
Bill Lee
AMA 20018
Offline Bootlegger
Re: ..Math..
« Reply #4 on: November 30, 2013, 01:36:51 PM »
  Thanks a lot fellows...
Gil Causey
AMA# 6964
Re: ..Math..
« Reply #5 on: November 30, 2013, 04:16:37 PM »
Gordon's example contains an error: he starts with a diameter of 0.25", then jumps to 0.20".  So the "real" answer using his method is:
total area: (0.25")2(pi/4) = 0.04909 sq in
blocked area: (0.25")(0.159") = 0.03975 sq in
total un-blocked area: 0.04909 - 0.03975 = 0.00934 sq in
Bill's example is more accurate, but oh, the math:
ventarea = 0.25^2 * pi/4 = 0.04909 sq in
Y = sqrt(0.25^2 - 0.159^2) = 0.19292"
alpha = atan(0.159 / Y) = 39.50 degrees
arcArea = ventarea * 4 * alpha / 360 = 0.02154 sq in
triangleArea = Y * 0.159" / 2 = 0.01534 sq in
blocked area = triangleArea + arcArea = 0.03688 sq in
unblocked area = 0.04909 - 0.03688 = 0.01221 sq in
Re: ..Math..
« Reply #6 on: November 30, 2013, 05:17:29 PM »
Now I know why I almost failed Algebra I.   If I had said I was going for Algebra II, it would have flunkville for me.
Re: ..Math..
« Reply #7 on: November 30, 2013, 06:15:41 PM »
Aki
If you enter ".25" for the venturi diameter instead of "0.25" it thinks the diameter is 2.5", and messes up the calculations.  It seems to be fine with ".159" for the spraybar diameter, though.
Offline BillLee
Re: ..Math..
« Reply #8 on: November 30, 2013, 07:06:22 PM »
That's not a bug, that's a FEATURE!  ;D
The code builds the image that is returned and saves it in a file on the server. If someone comes in later and asks for the same parameters, the code just serves up the previously created image instead of re-creating it. The image for the combination of .25x.159 was wrong, and hence it gave a wrong answer.
Fixed now. Correct answer is given.
Bill Lee
AMA 20018
Re: ..Math..
« Reply #9 on: November 30, 2013, 07:19:49 PM »
Ok Ok I was typing too fast. but the formula and method is valid. and No I did not Fail Algebra! and as stated it does not allow for the arc at the end of the spray bar. But it is close enough for what we do.
