I cut the leadouts off at the bellcrank and removed them. Removed the bellcrank. Took a morris bellcrank, and made a bushing so I could use the stock bellcrank platform and bolt. I fished a 1/32 rod of music wire through the wing. I have some small Teflon tubing that just fits over the morris leadouts. shoved a short piece of the tubing on the end of the wire and the end of the leadout. A couple of drops of ca secured the wire and leadout in place, and I used the wire to pull the leadout through the wing and the leadout guide.
