  • July 18, 2025, 09:04:24 AM
Author Topic: "O" rings  (Read 2748 times)
Offline Bootlegger
"O" rings
« on: April 04, 2010, 01:03:23 PM »
  Guy's where, other than Tower can I get some "o" rings for the venturi's on OS engines ??
 Thanks, Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Perry Rose
Re: "O" rings
« Reply #1 on: April 04, 2010, 01:17:39 PM »
The local auto parts store may have them.
Offline Jim Thomerson
Re: "O" rings
« Reply #2 on: April 04, 2010, 01:22:48 PM »
Local hardware store.
Offline Bill Heher
  • Fix-it
Re: "O" rings
« Reply #3 on: April 04, 2010, 03:08:52 PM »
ACE Hardware stores usually have a full selection, Home Depot and Lowes are hit or miss. Take your venturi with you, it is OK to stretch an o-ring a little to get it to fit, the stock OS ones are a small dia. cross section anyway. Smaller is better than slightly too big, that may leave a gap somewhere and result in an air leak.
Bill Heher
If it's broke Fix-it
Re: "O" rings
« Reply #4 on: April 04, 2010, 03:19:38 PM »
    Which, as it turns out, doesn't make a huge amount of difference. I saw a guy run half a season with both no o-ring to seal the venturi to the case, and. the fuel leaking into the engine around the right angle fitting, along the external threads on the spraybar, into the case, and in between the case and venturi. This was only a problem when it got hot enough that he bottomed out the needle and it was still too rich!  It ran pretty much OK otherwise, and fixing it only improved the needle response.
     For a "through the center" spraybar the only really critical leak area is around the threads of the needle. It's not recommended to let it leak elsewhere,  but it's not necessarily a show-stopper, either.
    Of course, with a sprinkler venturi any leak, even a tiny one, anywhere,  makes a huge difference and *everything* has to be sealed up tight for consistent results. Including where the spraybar goes through the case - even the air leaking through the bead-blasting make a distinct difference. Silicone bathtub caulk is your friend and you will see it all around the front of any of my sprinkler venturi engines.
Offline Andrew Borgogna
  • Andy
Re: "O" rings
« Reply #5 on: April 04, 2010, 08:17:45 PM »
I get mine at True Value Hardware store, they have a nice selection of "O" Rings.
Andy
Andrew B. Borgogna
Offline Marvin Denny
Re: "O" rings
« Reply #6 on: April 04, 2010, 08:46:04 PM »
  Another place is the local RC car corner of the local hobby shop
  Bigiron
marvin Denny  AMA  499
Offline Dick Pacini
Re: "O" rings
« Reply #7 on: April 04, 2010, 08:56:10 PM »
Not all O-rings are suitable for our applications.  Of interest is how they stand up to the ingredients that make up model engine fuels.
Here is an informative chart that has lots of info.  Click on the Fluid Compatibility Guide and scroll down to nitromethane, for example.
http://www.marcorubber.com/material_chart.htm
AMA 62221
Offline Scott B. Riese
  • Just a student of stunt
Re: "O" rings
« Reply #8 on: April 05, 2010, 03:46:30 PM »
ENCO.COM
.010, .011, .012, .013
Are the size's
Scott Riese
Portland, Oregon
AMA 528301
Re: "O" rings
« Reply #9 on: April 06, 2010, 05:40:56 AM »
A little bead of Silicone Glue wil do the same thing if all parts are cleaned up first.   H^^
