  • July 02, 2025, 06:31:29 AM
Author Topic: "My Way" Construction Pictures  (Read 1003 times)
Online Peter Germann
« on: April 05, 2018, 04:58:24 AM »
Here is a bit of added information
Peter Germann
ron young
Re: "My Way" Construction Pictures
« Reply #1 on: April 05, 2018, 05:30:34 AM »
Wow very very well done if only I could build like that .
Thanks for sharing
Ron
Offline Al Takatsch
« Reply #2 on: April 05, 2018, 06:26:01 AM »
Hi Peter,
What is your prefered way to connect pushrod to bellcrank?
What type of bellcrank do you use?
Nice work, love to see it fly.
Al T.
« Reply #3 on: April 05, 2018, 08:26:22 AM »
Bellcrank is made from two pieces of 1/16 in Epoxy printed circuit bord material. I have uploaded a drawing named "Steuerung" showing dimensions. All connections are commercial 3 mm  (1/8") ball-links, modified for minimum friction.
Peter Germann
Offline Al Takatsch
« Reply #4 on: April 05, 2018, 10:34:07 AM »
 Thank you Peter,
What type of bellcrank bearing did you use or fabricate?
Al T.
« Reply #5 on: April 05, 2018, 11:21:00 AM »
1/8 piano wire shaft running in a brass tube 1/8 ID x 3/4 in long. Greased for life at time of installation.
« Last Edit: April 05, 2018, 11:42:13 AM by Peter Germann »
Peter Germann
Offline Vincent Judd
« Reply #6 on: April 05, 2018, 01:41:48 PM »
Beautiful job Peter, thanks for sharing photos and all design information, very interesting.
Vince
